Latest: elelectricistadeMateo
Overall: 17127
Online Now [55]:
Visitors: 54
Today: 674
Total: 100398913
Forums › The Car › 206 Problems › my 1.1 206 is dead :(
jamesH
PostPosted: Wed Apr 10, 2013 5:30 am Up
hi all, im new to the forum and was recommended to join the site as i need information, guidance and advice on my little car,
Background:
so the car sounds like death and is seriously underpowered and cant even go up a slight incline!!! so managed to take it to a garage and they said it would be the spark plugs so they changed them nothing... they then changed the ht leads, coilpack.... nothing to then say they dont know what to do next?
so now im stuck as ive spent loads on trying to find the problem to the point were im now thinking of spending more money on a complete engine change? good idea?
so now i need as much advice/ guidance as possible...
i have a 1999 1.1 206, which engine would be best to go for? and a straight swap? i dont mind changing the engine loom and ecu?
cheers all!
Big_Rich180
PostPosted: Wed Apr 10, 2013 5:32 am Up
Welcome.
Sack it off and buy a car that works, changing an engine will probably cost you just as much as I presume you wont be doing the work yourself as you let a garage change your spark plugs?
jamesH
PostPosted: Wed Apr 10, 2013 5:44 am Up
Big_Rich180 wrote:
Welcome.
thank you for the welcome.
i can do it myself but i didnt know what the problem was so i went to the garage to get help and they ensured me they knew what it was and at £20 i didnt mind them changing them as they said that was the problem and it was a pain in the a** to get it there so i didnt want to drive it all the way back in the same state!
PostPosted: Wed Apr 10, 2013 6:16 am Up
Petrol 206's don't have HT leads.
Mr-Tigger
PostPosted: Wed Apr 10, 2013 7:02 am Up
As above,if they told you they changed "ht leads" then i would be a bit cautious about going back to them to do anything else
jamesH
PostPosted: Wed Apr 10, 2013 7:20 am Up
okay guys cheers, any idea on what engine conversion would be the easiest to do?
PostPosted: Wed Apr 10, 2013 7:21 am Up
Engine swap would be easiest, if you've decided that he engine is dead. A proper code read would be easier than guessing. You could pick up a second hand engine for cheap and fairly easy to fit yourself with the right tools.
jamesH
PostPosted: Wed Apr 10, 2013 7:29 am Up
what engine would you recommend? that would most cost efficient!
20Drift
PostPosted: Wed Apr 10, 2013 7:33 am Up
1.4 Diesel Wink
Big_Rich180
PostPosted: Wed Apr 10, 2013 7:37 am Up
1.6 16v or 8v.
jamesH
PostPosted: Wed Apr 10, 2013 8:04 am Up
Big_Rich180 wrote:
1.6 16v or 8v.
what would this need? loom, unlocked ecu? engine with all the bits, suspension and brakes? any more?
know of any full conversions going for sale?
Mr-Tigger
PostPosted: Wed Apr 10, 2013 9:14 am Up
tbh if you're going bigger engine,by time you do brakes,shocks,other bits n pieces.... you're better off selling/breaking yours and buying a new one. i should have listened to such advice with my old 1.4 but i wasnt going for power,just downright noise which i achieved..... £3k later! then bought a GTi lol
