Online Now [501]:
Visitors: 500
Today: 33970
Total: 157056050
Forums › The Car › 206 Problems › Wiper hitting A pillar
Danz
PostPosted: Sat Apr 13, 2013 7:15 am Up
Hi I wonder if anyone can help, my drivers side windscreen wiper is hitting the A pillar. My dad replaced the blades a while back with Bosch ones and everything was fine but now it just scrapes the pillar.
The blades both measure 22" I think I read some where they are different sizes.
DannyBoy
PostPosted: Sat Apr 13, 2013 7:26 am Up
Different sizes depending on the year, and then different again if you've fitted the aero flat wipers.
Danz
PostPosted: Sat Apr 13, 2013 8:35 am Up
It's a 2004 with just the normal Bosch wipers not aero
DannyBoy
Simon2710
PostPosted: Sat Apr 13, 2013 12:50 pm Up
I'm sure you can alter the sweep of the wipers, when you open the bonnet right in the middle at the very top are two knobs you can twist. At least there is on mine.
Simon
PostPosted: Sun Apr 14, 2013 8:00 am Up
You need 21/21 with flat blades
Ghosty
PostPosted: Mon Apr 22, 2013 8:33 am Up
i was gonna say try a 21" blade on the drivers side cured it for me, i think lee you gave me that advice when i asked a while back.
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
Danz
PostPosted: Mon Apr 22, 2013 12:31 pm Up
Yep we changed it for a 21" at the weekend, all okay now
DannyBoy
longshortchris
PostPosted: Sun May 12, 2013 1:03 am Up
Ha!
This is the problem I have today. I snapped the Bocsh Aerotwin AR22U blades on & the drivers wiper is leaving a patch of dirty windscreen approx. 3"-4" wide along the length of the A pillar. When it's parked, you can see the top 3" is not resting on the windscreen. I look on the back of the box & it doesn't list any Peugeot models.
So, I then look at this site:
www.boschwipers.co.uk/...er-blades/
and Bosch only specify the 26"/19" combo for 206s built from 1998-2000. So, you can determine from that point that Bosch do not recommend any replacement flat wipers other than the former mention combo.
So, before www.wiperblades.co.uk get back to me with a response & a replacement for my drivers side wiper, may I ask if the 21" wiper fully cleans the area alongside the A pillar? The normal 22" wiper does this without a problem.
Chris
