Latest: heikkisj
Overall: 17126
Online Now [346]:
Visitors: 345
Today: 27396
Total: 100360352
Forums › The Car › 206 Problems › judder problem
judder problem
Achillez
PostPosted: Wed Apr 10, 2013 4:33 pm Up
Hello everyone, I hope someone may be able to help or have some advice.
I've had this problem since having this car, just under a year, when I remove my foot off the accelerater the car Judders, I notice this in all gears. I have noticed the car doesn't judder as bad if at all if I remove my foot while going about 55-60 mph.
At first I did think about engine mount but I'm not convinced anymore, if I put my car in 1st and go about 5mph and take my foot off the pedal it will judder. The car Judders every time you take your foot off the pedal, very bad at low speeds.
Very annoying and I really want to fix this, my car is 2003 xsi 1.6 16v
paulspug
PostPosted: Thu Apr 11, 2013 1:59 am Up
could be your bottom engine mount.Best check to see if the rubber has perished.
PostPosted: Thu Apr 11, 2013 4:04 am Up
Drop links??
Achillez
PostPosted: Thu Apr 11, 2013 12:30 pm Up
I've replaced both arms, track ends, drop links. None of them
PostPosted: Thu Apr 11, 2013 12:43 pm Up
If the judder is only when you take your foot off the accelerator, it could be linked to a fuelling/air flow problem.
Achillez
PostPosted: Thu Apr 11, 2013 3:47 pm Up
I've also changed thermostat, temp sensor and the map sensor if that helps at all.
DREWDEN
PostPosted: Fri Apr 12, 2013 11:09 am Up
Whilst changing into 2nd gear keep your clutch down, and come off the gas, if its not juddering, then
presumably could be bent or distorted dive shaft, inner cv joints.
206 2ltr Hdi glx 53 plate
PostPosted: Sat Apr 13, 2013 5:51 am Up
Exactly my thought, driveshafts up the spout.
Achillez
PostPosted: Sat Apr 13, 2013 1:24 pm Up
I've done just what you've asked me 2, I've tried it in all gears and no judder, just revs as I have my foot still on the accelerator Razz
So this means my Drive shafts are broken? I shall replace both sides and I'll come back with the results.
Many thanks
DREWDEN
PostPosted: Sun Apr 14, 2013 1:13 pm Up
Before you replace drive shaft/shafts, check the inner cv joints and the intermediate bearing (gearbox).
Outer shafts could be ok.
Good garage should be able to tell you what wants doing.
