Latest: heikkisj
Overall: 17126
Online Now [49]:
Visitors: 48
Today: 13968
Total: 100386687
Forums › The Car › 206 Problems › Drivers door stuck on dead lock
EuroPeugeot
PostPosted: Sat Apr 13, 2013 5:17 pm Up
So last night my alarm went off at 430am. I finally stopped it, although pressing the key fob didn't help. Had to put key into ignition. I took the battery of to make sure it didn't go off again.
When I reconnected the battery in the morning, the drivers door seems to be stuck on 'dead lock mode'. It cannot be opened from inside or outside the car. I have to climb out the passengers door! Sad
Any ideas? I'm guessing this happened because I didn't disconnect or reconnect the battery properly, as per the multi-plex way
RE: 2004 GTi 180.
EuroPeugeot
PostPosted: Sun Apr 14, 2013 7:33 am Up
Anyone know a reset or something I can do?
Tolkienfan001
PostPosted: Sun Apr 14, 2013 8:41 am Up
Trade Rating: +13
TBH I have no idea. The first thing I would try is a correct BSI reset procedure. There is a guide on here. I used it when changing my comms unit.
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Sun Apr 14, 2013 8:43 am Up
Rest the BSI, and leave the power disconnected for about 30 minutes to allow the power to die down from all the capacitors....then try.
Also the key in the lock should work, and try unlocking the door with the key when the battery is off!
EuroPeugeot
PostPosted: Sun Apr 14, 2013 11:21 am Up
Did the sort reset and didn't work. Also the key turns the lock obviously, but still won't open.
Any ideas on what to try next? Surely no way in getting the door card off without damaging it, right?
Tolkienfan001
PostPosted: Sun Apr 14, 2013 11:26 am Up
Trade Rating: +13
I believe Mr BSI knows a way to remove the barrel with out damage this may help you?
2005 1.4 16v Sport
EuroPeugeot
PostPosted: Sun Apr 14, 2013 1:25 pm Up
Yeah I guess that's what I'm going to need to do Sad
Although, I cant believe the drivers door barrel suddenly faults at the same time I get an alarm / electrical fault
Can someone also confirm how to dead-lock a MUX 206. I sat in the car. Locked the car via the key fob. Then pressed the lock button again and hear a locking 'sound', but I can still open the car from the inside. This shouldn't be able to happen, right?
Hawkers
PostPosted: Sun Apr 14, 2013 1:46 pm Up
Try and start the car, I read a post by mr bsi that this should reset the deadlocks as a safety feature. Unless you've already tried that.
Also pressing the lock button a second time deactivates the deadlocks.
EuroPeugeot
PostPosted: Sun Apr 14, 2013 1:51 pm Up
Yeah I've tried starting the engine etc. How do I activate the dead locks then?
Hawkers
PostPosted: Sun Apr 14, 2013 1:57 pm Up
Providing you have the key fob with the 2 buttons. When you press the lock button this will set the alarm and the deadlocks, pressing the lock button a second time within 10? seconds will deactivate the deadlocks but keep the alarm active.
