Online Now [304]:
Visitors: 302
Bots: 2
Today: 114084
Total: 155070788
Forums › The Car › 206 Problems › Plastic wheel nut caps
Tolkienfan001
PostPosted: Sun Apr 14, 2013 8:36 am Up
Trade Rating: +13
I keep losing caps.
Either elves are taking them or they are so old now they fit too loosely.
I am going to guess it is the second reason.
So should I buy them from eBay or peugeot?
Does anyone know the price for a set from peugeot?
Also on eBay there are 17mm or 19mm. Which ones do I need please?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Sun Apr 14, 2013 8:41 am Up
I'd probably say eBay maybe cheaper due to them not having to be Peugeot specific, you can just by generic ones.
17mm or 19mm.....depends on the size of your wheel bolts.
Tolkienfan001
PostPosted: Sun Apr 14, 2013 8:52 am Up
Trade Rating: +13
Ok thanks I will measure and order on eBay. Thanks for the quick response. Much appreciated.
2005 1.4 16v Sport
iainlovatt
PostPosted: Sun Apr 14, 2013 9:02 am Up
Pm'd
(My Garage)
PostPosted: Sun Apr 14, 2013 9:13 am Up
My 206 uses 19mm bolts.
Tolkienfan001
PostPosted: Sun Apr 14, 2013 9:15 am Up
Trade Rating: +13
Alloys?
2005 1.4 16v Sport
PostPosted: Sun Apr 14, 2013 10:32 am Up
Tolkienfan001 wrote:
Alloys?
Mine are 19mm alloy bolts to.
Tolkienfan001
PostPosted: Sun Apr 14, 2013 10:36 am Up
Trade Rating: +13
Thank you guys I have just measured and mine are 19mm Smile
2005 1.4 16v Sport
gazza82
PostPosted: Sun Apr 14, 2013 10:47 am Up
You can get 17mm and 19mm alloy wheel bolts.
If you go for ebay ones, I hope yours are better than the ones I bought ... far too loose and keep dropping off. Not helped I guess by the cr@p road surfaces we have to put up with.
Tolkienfan001
PostPosted: Sun Apr 14, 2013 10:53 am Up
Trade Rating: +13
Yea lets not get started on the condition of the roads!
I have just had my alloys referbed and the way I am dodging pot holes, at some point I will get pulled over! I have been driving for over 12 yrs and have never been pulled over.
I feel my first time is close! Smile
2005 1.4 16v Sport
PostPosted: Sun Apr 14, 2013 11:40 am Up
The 207CC had 17mm bolts. If the covers are loose then but a small bit of paper between bolt head and cover.
Tolkienfan001
PostPosted: Sun Apr 14, 2013 11:53 am Up
Trade Rating: +13
Might try that. Thanks
2005 1.4 16v Sport
PostPosted: Tue Apr 16, 2013 5:44 am Up
Mrs' 206 has 17mm bolts also from factory. It's a 2008 1.4i.
Ghosty
PostPosted: Mon Apr 22, 2013 8:30 am Up
there only £1.50 or so each from dealer, i had to get 2 a while back
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
