Latest: TigerHunters
Overall: 17144
Online Now [69]:
Visitors: 68
Today: 2277
Total: 115875781
Forums › The Car › 206 Problems › 206 Coilovers
206 Coilovers
Zack
PostPosted: Tue Apr 16, 2013 8:33 am Up
Right I have fitted coilovers before on my 206s i have had but I always take the helper springs out one to go lower and two so it is easy to compress the damper. But I keep wrecking the coilovers by doing this so going to do it right.
How do people fit them with helper springs in?
Cheers
Uz
PostPosted: Tue Apr 16, 2013 11:32 am Up
Strip them down, wind the spring seats all the way down. Slot the helper spring in, the splitter seat and then the normal spring, coilover top mount bush and just drop the top mount on with the rubber rush and bolt it up. Piece of p**s.
Zack
PostPosted: Tue Apr 16, 2013 11:38 am Up
No how to do all that just when it come to putting the coilover back its a right pig.
206gti_chris
PostPosted: Tue Apr 16, 2013 11:43 am Up
maybe use coil spring compressors ?
Zack
PostPosted: Tue Apr 16, 2013 11:45 am Up
What these?
www.screwfix.com/p/coi...2pcs/45986
Uz
PostPosted: Tue Apr 16, 2013 11:53 am Up
You don't even have to use spring compressors. If you've got decent coilovers the springs will be short enough to be able to do it without anything. Just slot and bolt.
Zack
PostPosted: Tue Apr 16, 2013 11:55 am Up
So what make do i need so dont have to use spring compressors
Uz
PostPosted: Tue Apr 16, 2013 12:15 pm Up
Try pushing down on them... if they're cheap ass coilovers you'll push down with one hand and put the bolt on the thread with the other.
Zack
PostPosted: Tue Apr 16, 2013 12:34 pm Up
Yea i can do that. its when the coilover is together and you put the top mount to the car and then the coilover is to long to easy put it in the bottom.
cheers
Uz
PostPosted: Tue Apr 16, 2013 12:39 pm Up
To get them in the car it's ideally a 2 man job so you can push the wishbone down with a large pry bar and that way the hub drops down and you position it into place.
Zack
PostPosted: Tue Apr 16, 2013 12:41 pm Up
Thats what i try and i crap my self bout the drive shaft coming out.
Uz
PostPosted: Tue Apr 16, 2013 12:51 pm Up
passenger side will and p**s all the gearbox oil out so get them fitted and fill the oil back up. Drivers side will stay in without a problem.
Zack
PostPosted: Tue Apr 16, 2013 12:53 pm Up
I got told that once it falls out you have to take gear box off to put them back in?
cheers
PostPosted: Tue Apr 16, 2013 1:32 pm Up
Helper springs just stop the spring becoming unseated when jacking up, once the car is lowered it won't make a difference and certainly doesn't damage the unit
As long as you make sure it's positioned correctly when the jack is let down you will be fine
If the shaft comes out just pop it back in and top it up with oil
Zack
PostPosted: Tue Apr 16, 2013 1:50 pm Up
Fair enough thanks Smile everyone
