Latest: heikkisj
Overall: 17126
Online Now [37]:
Visitors: 36
Today: 2787
Total: 100217232
Forums › The Car › Solved 206 Problems › VSS and it's wiring
VSS and it's wiring
Spiky
PostPosted: Thu Feb 02, 2012 4:19 pm Up
hi,
my 206 hdi speedo isn't working
i have tried the trick of driving the door open and nothing
so might be vss or the wiring
does anyone know the wire number that is on the rear of the clocks, so i can use a multimeter to check the wire?
also any one got a known working VSS for 2000x hdi 90 for sale?
PostPosted: Thu Feb 02, 2012 4:25 pm Up
Read the live data, it's easier.
Spiky
PostPosted: Wed Feb 08, 2012 4:03 pm Up
How would I do that? Via obd?
206 HDI Dturbo X/2000
Spiky
PostPosted: Wed Apr 17, 2013 1:37 pm Up
Fixed now
Run a new cable from ecu to rear of the clocks
All fine now
And now the interior light flashes if the door is open
That didn't work until I added new cable
PostPosted: Wed Apr 17, 2013 2:09 pm Up
So where's the break? Down at the plug behind the front bumper?
Spiky
PostPosted: Wed Apr 17, 2013 2:13 pm Up
I don't know
Just run a new cable. One day will trace where the brake is
As my air con and my bottom driving lights don't work so must be a damage loom somewhere
Don't know which way the wires run but assume passenger side
