Latest: Andyblue64
Overall: 17123
Online Now [292]:
Visitors: 291
Today: 13681
Total: 98637081
Forums › The Car › 206 Problems › Engine cutting out
Engine cutting out
gibbs-
PostPosted: Wed Apr 24, 2013 5:24 am Up
Hey guys,
My 206 has done this every other month or so for the last year, but now its becoming far more regular.
When waiting in traffic or parked up with the engine running, sometimes when it is just ticking over, the car will just die - and then it will take about 10 minutes of having the engine off before I can coax it back to life by starting with my foot on the accelerator.
Today however I started the car normally, but it immediately died - and after starting it again with my foot down as soon as I took my foot off it wouldn't even tick over - it would just die.
Started it again to get a video of what happens, but of course it didn't die! Still shows issues with revs though, so here's the vid. Any time it goes above 1k revs I have revved it, but the rest is the engine doing it on its own (such as the 'constant 800 revs' being a pulsating rev! Also, normally when it umps down to 200 revs it dies, it didn't today for osme reason!
Here's that video
www.youtube.com/watch?v=gFe8DvT0h6I
Any ideas? Cheers guys! Really annoying problem as unpredictable and means I just can't trust the car!
X-Reg, 1.6, 206 XS.
Deckchair5
PostPosted: Wed Apr 24, 2013 5:56 am Up
Always difficult to diagnose from a distance but as your idle rpm is oscillating every sec and it's struggling to hold idle then I'd want to check the pre cat O2 sensor running data. You could do a simple check and view the voltage output from the signal wire at tickover looking for an oscillating voltage between 0.1- 0.8v every sec
Pre cat O2 sensor again? So many of them lately
Look for stored fault codes but don't always expect them on the O2 sensor as it may still be within limits but still have very poor response
Other clues might be very poor fuel consumption as it's needed to fine trim the fuel/air at steady engine rpm. The poor restarting and needing floored accelerator indicates a very rich condition which again can be caused by a poor O2 sensor signal
gibbs-
PostPosted: Sun May 19, 2013 3:48 pm Up
Another small add-on to this issue: The other day when travelling around 60mph, the speedo went to 0 but the engine was still running and I was still going along at 60. I changed down a gear and slowed a bit, and the speedo shot back up. Don't know if this is connected!
X-Reg, 1.6, 206 XS.
eddie206
PostPosted: Sun May 19, 2013 11:12 pm Up
I watched the film and i noticed you havnt mentioned the odd behavior of the far right temp gauge...if you look it hits max. with a red light within the gauge then 3or4seconds after starting the ligjt goes and the needle drops to zero...
This strange behavior along with your speedo gliche would point to the need for a bsi reboot but the reboot is unlikely to be the cause of your stalling and misfiring....these symptoms are often rectified by cleaning the ICV thats the Idle Control Valve however....it could be something else entirely...read the codes if your getting any and you can access a code reader?
keep us up to date?
gibbs-
PostPosted: Mon May 20, 2013 4:32 am Up
The temp gauge act as an oil level gauge when turned on (or so I was told) , then changes to be a temp gauge when the car's been on a few seconds.
Not got any access to a reader unfortunately, but will look in to the ICV , Thanks
X-Reg, 1.6, 206 XS.
eddie206
PostPosted: Mon May 20, 2013 5:54 am Up
Are you sure because my mileage readout is the oil level gauge on my 2002 138gti but is multi plexed?
PostPosted: Mon May 20, 2013 5:59 am Up
Non plexed is totally different for the oil level gauge.
eddie206
PostPosted: Mon May 20, 2013 2:30 pm Up
I must say its quite reassuring to find these cars have little extras like that...someones really thought about putting the 206s together...
When they work of course.
