Latest: Mr-Koekwaus
Overall: 17125
Online Now [41]:
Visitors: 40
Today: 21448
Total: 99931974
Forums › The Car › 206 Problems › engine management light comes on in the rain
bridge9
PostPosted: Sun Nov 18, 2012 5:13 pm Up
hi, any one got any ideas, i have a 2004 206 diesel 1.4 which i got a few months ago, i love it but every time it rains the engine light comes on then after a while the car keeps cutting out. got 2 codes one said something about fuel pump and the other said some thing about intake. i was told that some times water runs up the headlight and gets into the air intake so i fixed this from happening. also someone said change fuel filter. didn't work. don't realy have the money to go to auto electrician. just checking to see if there is a common fault? the pollen filter needs changing and the car steams up a lot,, could the built up of moisture in the cabin be getting onto some of the circuits and causing my problem? i will be changing the filter ASAP anyway. thanks in advance Mad
PostPosted: Sun Nov 18, 2012 5:16 pm Up
Codes might help......
PostPosted: Sun Nov 18, 2012 5:21 pm Up
heavy rain or light rain?
PostPosted: Sun Nov 18, 2012 5:36 pm Up
Wet or Dry rain?
PostPosted: Mon Nov 19, 2012 2:44 am Up
Don't put WD40 on all the connectors.
Use a proper contact-spray instead if you have to.
bridge9
PostPosted: Mon Nov 19, 2012 6:20 am Up
hi guy i had the codes but can't find where i put them, doh but its heavy rain, and wet of course lol!!! thanks again!
bridge9
PostPosted: Wed Nov 21, 2012 4:47 pm Up
hi again, i found the codes p1160 and p0087?
PostPosted: Wed Nov 21, 2012 7:13 pm Up
well...
p1160 is IAT sensor short circuit
p0087 is low fuel rail pressure
it will have to be the p0087 causing the engine cut out problem; since you don't have an in-tank fuel pump. All i could think of is there is something wrong with your injector pump or blockage in the fuel pipe.
Antknee
PostPosted: Wed Nov 21, 2012 7:42 pm Up
sounds like the car is getting wet or something
Rob2859
PostPosted: Wed Nov 21, 2012 9:24 pm Up
Have you got a DIY air intake?
Are you sure its not coincidence?
Ant, you genius, you could be right.
PostPosted: Thu Nov 22, 2012 8:05 am Up
What happens when you wash the car. Do the Polish not get a bit naffed off having to push your car out of the line?
Don't drive the car when it's raining. Problem solved.
bridge9
PostPosted: Wed Apr 24, 2013 4:33 pm Up
as yes some very good answers there guys!!!! anyway i took the pollen filter out the other morning before i left the house ( it was raining(( not the filter but the sky)) )and gave it a good clean. hey presto no steamed windows and the light never came on!!so i guess this is the problem. a new filter should do the trick. so if anyone is having the same probs try this!!!! thanks......now on to the next problem Smile
