Latest: Mr-Koekwaus
Overall: 17125
Online Now [268]:
Visitors: 267
Today: 110911
Total: 99616056
Forums › The Car › 206 Problems › OBD2 code P2096
OBD2 code P2096
ssjgoku101
PostPosted: Thu Apr 25, 2013 7:42 am Up
Hey guys,
My car displays the fault code P2096 with an OBD2 reader. Can anyone tell me what's wrong with it and what need fixing?
Baz
Tolkienfan001
PostPosted: Thu Apr 25, 2013 8:12 am Up
Trade Rating: +13
According to Mr Google fuel to lean possible O2 sensor fault....
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Thu Apr 25, 2013 10:00 am Up
Or leaking exhaust before lambda sensor allowing air (that contains O2) into the exhaust system. The sensor "sees" the extra O2 and assumes the car is running lean. Lambda sensors are "narrow band" and will only cope with small variations either side of the expected range.
Tolkienfan001
PostPosted: Thu Apr 25, 2013 10:08 am Up
Trade Rating: +13
You can google any answer, but without background knowledge you can easy miss things! Wink
2005 1.4 16v Sport
ssjgoku101
PostPosted: Thu Apr 25, 2013 11:01 am Up
Hmm well in that case i'm pretty sure it must be the sensor because I've got a relatively new exhaust that was welded at the joints. Do you know which sensor it might be?
Baz
PostPosted: Thu Apr 25, 2013 11:07 am Up
You don't even need to use Google. This site already has the answer on it
www.206info.co.uk/Foru...c/t=34915/
ssjgoku101
PostPosted: Thu Apr 25, 2013 11:17 am Up
'Post Catalyst Fuel Trim System Too Lean (Bank 1)'. So its the post cat lambda sensor? What does bank 1 mean?
Baz
Tolkienfan001
PostPosted: Thu Apr 25, 2013 11:18 am Up
Trade Rating: +13
Did not know that list was on here Very Happy
2005 1.4 16v Sport
