Online Now [463]:
Visitors: 462
Today: 151285
Total: 156865970
Forums › The Car › Request a how-to › Request: How to change the head gasket of a 1.4 16v (ET3J4)
adzar
PostPosted: Sat Apr 27, 2013 10:31 am Reply with quote Up
Does anyone have a how-to/guidance on changing the head gasket of a 1.4 16v sport (ET3J4)?
Would be very much appreciated.
1.4 Sport
PostPosted: Sat Apr 27, 2013 11:16 am Reply with quote Up
Give me a couple of days and I will post up a full guide
adzar
PostPosted: Sat Apr 27, 2013 11:49 am Reply with quote Up
Amazing, thanks very much!
1.4 Sport
PostPosted: Sat Apr 27, 2013 12:39 pm Reply with quote Up
What are you doing with one of these engines?!! Laughing
PostPosted: Sat Apr 27, 2013 5:30 pm Reply with quote Up
Im not yet mate Wink
adzar
PostPosted: Sat Sep 07, 2013 3:32 am Reply with quote Up
Does anyone know what size/type of socket to use on the head gasket bolts? They are a 6 pointed star shape.
1.4 Sport
PostPosted: Sat Sep 07, 2013 4:18 am Reply with quote Up
If you can't spot a torx head on a bolt you're out of your depth doing a head gasket change. I would guess you don't have a torque wrench either?
PostPosted: Sat Sep 07, 2013 4:40 am Reply with quote Up
There is a good guide in the Haynes manual Wink
adzar
PostPosted: Sat Sep 07, 2013 5:06 am Reply with quote Up
I can only see the bolt length to check for and torques in Haynes.
1.4 Sport
PostPosted: Sat Sep 07, 2013 8:30 am Reply with quote Up
You need to change the bolts as there stretch type i.e. you can only use them once.
adzar
PostPosted: Wed Sep 11, 2013 10:49 am Reply with quote Up
E-14 is the answer
1.4 Sport
tlsjk
PostPosted: Wed Sep 11, 2013 2:40 pm Reply with quote Up
if you need a how to then you SHOULDNT be doing it!!!
adzar
PostPosted: Thu Sep 26, 2013 10:34 am Reply with quote Up
Question for re-assembly:
The haines manual gives the inlet sprocket retaining bolt torque as:
stage 1 = 20Nm
stage 2 = 60Nm
What is the procedure for tightening a single bolt in two stages?
There doesnt appear to be any specific reference to the two torques in the manual as there was for the head gasket bolts for instance.
1.4 Sport
  Quick Reply
Username:
Message:
Quote the last message
