Online Now [1304]:
Visitors: 1303
Today: 153458
Total: 155245110
Forums › The Car › 206 Problems › os/f bleed nipple snapped
P77TTN
PostPosted: Sat Apr 27, 2013 10:47 am Up
hi guys
well as it says above i have managed to snap the bleed nipple on the drivers side front caliper on my GT. i have checked and it has snapped in the clossed position and there is no leakage .
am i correct to assume it is ok to drive ???????????????/ Mad
206 Grand Tourisme 1385....
usher
PostPosted: Sat Apr 27, 2013 11:49 am Up
i wouldnt as i have driven without a pipe attached there are no brakes whatso ever not worth it, get a new caliper for less than 30quid
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
P77TTN
PostPosted: Sat Apr 27, 2013 11:56 am Up
there is no change to the brakes just the end of the bleed nipple has snapped in the clossed possition . it did not open when i tried to undo it . i have pumped the brakes and no fluid leaks
PostPosted: Sat Apr 27, 2013 12:29 pm Up
Well in theory then it should be ok...but there's only one way to fix it properly. As it's snapped closed then you can still use the car while waiting for the new one to arrive.
P77TTN
PostPosted: Sat Apr 27, 2013 3:30 pm Up
good time to upgrade me thinks!!!!!! any ideas on a good upgrade!!!!!
PostPosted: Sat Apr 27, 2013 4:29 pm Up
Easy.. drill a hole in the nipple until fluid can run through.
14hdi
PostPosted: Sat Apr 27, 2013 4:45 pm Up
drill it out to the next size thread and put a helicoil in and a new bleed nipple.
imjeeves
PostPosted: Sat Apr 27, 2013 8:27 pm Up
Just buy a new caliper. You can spend a day doing all that and its £30 for a whole new one from GSF
usher
PostPosted: Sun Apr 28, 2013 2:41 am Up
180 calipers and discs are cheapest upgrade
project thread WIP
garage
FAQ
206 gti firedance
P77TTN
PostPosted: Sun Apr 28, 2013 6:16 am Up
just checked on GSF £119 each Crying or Very sad
usher
PostPosted: Sun Apr 28, 2013 6:33 am Up
Ebay it
project thread WIP
garage
FAQ
206 gti firedance
