Latest: elelectricistadeMateo
Overall: 17127
Online Now [64]:
Visitors: 63
Today: 24172
Total: 100396848
Forums › The Car › 206 Problems › 206 rear beam
206 rear beam
Leegsi
PostPosted: Mon Apr 29, 2013 8:08 am Up
Just noticed I have quite a bit of play in the rear beam.
Are all the beams the same from model to model and not engine based.
Ie if I have drums and ABS I just need to fit a Drum and ABS rear beam from any 206?
Also can the bearings be replaced and if they can is there a guide as the guide on here has no pictures.
nellyhaggis
PostPosted: Mon Apr 29, 2013 12:03 pm Up
There is a guide on here somewhere.
The bearings are about 40 for the beam but getting the old arms off is the tricky bit.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
Sounds like this beam is already beyond just a set of bearings Laughing
ukskater01
PostPosted: Mon Apr 29, 2013 2:38 pm Up
Listen to mr bsi! I had play in my o/s/r wheel, it was wobbling so bad it was touching the body. I stupidly had it repair and within a year it happened again! By the time you have play it normally means the beam has worn out. I had to replace my axle with a recon in the end. I just wish I'd replace mine in the first place!
PostPosted: Mon Apr 29, 2013 3:26 pm Up
Put it this way. Bearing in good condition and there's no movement in the rear axle. Imagine what the axle must be like on a car with movement in the trailing arms.
Leegsi
PostPosted: Mon Apr 29, 2013 3:49 pm Up
Wheres the cheapest place to buy one?
