Online Now [416]:
Visitors: 414
Members: 1
Today: 130220
Total: 155223148
Forums › The Car › 206 Problems › 1.6 HDI Loss of Power
nellyhaggis
PostPosted: Mon Apr 29, 2013 5:56 pm Up
Hi,
Hoping someone might be able to help.
My car sometimes idles a bit odd, revving a little bit quicker then going back to normal.
And it struggles sometimes to accelerate then its fine then it struggles again like its being starved of fuel.
Ive had the fault code read and nothing.
Any help would be great.
Cheers.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
DREWDEN
PostPosted: Mon Apr 29, 2013 7:56 pm Up
Is connected to your speed sensor problem, as Lee Thu kindly advised me in one of my threads i did recently
concerning my ABS fault. (cracked ring)
Should be fine i guess when you get speed sensor sorted.
206 2ltr Hdi glx 53 plate
nellyhaggis
PostPosted: Tue Apr 30, 2013 4:41 am Up
I've had it up on the ramp today and the front drivers abs ring is cracked.
New ordered, hopefully that should cure it.
nellyhaggis
PostPosted: Sun Jun 23, 2013 6:01 pm Up
Just an update on this.
I had to replace the whole cv joint as my abs rings were 86mm which were near impossible to buy.
I managed to find some cv joints for £10.99 online (JR on ebay) banged them on and I now have full power with working abs atlast.
Oww ye and i changed the engine idle speed sensor whilst it was off to be on the safe side.
PostPosted: Mon Jun 24, 2013 6:53 am Up
Nice to know it is fixed but by doing two thingts at once you don't know if it is ABS ring or idle speed sensor.
You may be happy that it is fixed but I hate not knowing the real root cause of a proble.
