Online Now [639]:
Visitors: 638
Today: 65953
Total: 155163001
Forums › The Car › Request a how-to › Rear ABS sensor change
ssjgoku101
PostPosted: Tue Apr 30, 2013 9:37 am Reply with quote Up
Hi
I'm looking for a guide on removing and changing the rear ABS sensor. It seems much harder to access than the front sensors.
PostPosted: Tue Apr 30, 2013 10:18 am Reply with quote Up
Seems fairly straight forward when ive looked at mine.
ssjgoku101
PostPosted: Tue Apr 30, 2013 10:19 am Reply with quote Up
Do you need to remove the rear disc to get access to it? Seems a bit of a struggle otherwise.
Baz
PostPosted: Tue Apr 30, 2013 1:40 pm Reply with quote Up
I was trying to find the removal procedure on my service box, doesn't mention the ABS sensors though. Just unplug the wiring under the wiring under where the rear axle connects to the car, blue connector off the top of my head. Trace the wiring back to the sensor behind the disc, its only screwed in. Removing the disc might be easier.
Have you got a problem with yours?
ssjgoku101
PostPosted: Tue Apr 30, 2013 7:21 pm Reply with quote Up
Yeah, I've got a rear ABS sensor fault, had it diagnosed.
Yes it was the blue connector, I followed the wire back and took the screw out but the unit seems to be lodged in there tight. Can't seem to pry it out.
Baz
ssjgoku101
PostPosted: Thu May 02, 2013 10:17 am Reply with quote Up
Okay I've changed it now.
These sensors are a b***h to change when seized.
Procedure if rear sensor is seized:
Remove calliper, disc and heat shroud, lob the top plastic head of the sensor off with a screwdriver and hammer. Smack the sensor out through the other side of the bore hole, taking care not to damage the ABS ring. Use needle nose pliers to pull it out through the hub. May need to break off the tip of the sensor to allow it to fit through the gap on the hub side.
Or... heat up the surrounding area and avoid all of this effort lol.
Cleaned up the ABS ring because it was full of grime. Put the new sensor in and NO MORE ABS FAULT Very Happy
Baz
  Quick Reply
Username:
Message:
Quote the last message
