Forums › The Car › 206 Talk › Front brake caliper rebuild |
Posted: Tue Apr 30, 2013 11:29 am |
I have a 2001 1.4 lx and I have brought some front calipers off a 2004 1.4 lx.They look the same only the caliper mounting bracket are slightly different.
I have stripped the calipers which are the bosch single 48mm piston calipers,on the bracket can anyone tell me how to replace the rubbers on the caliper mounting bracket. Do they just pull out. Thanks
Posted: Tue Apr 30, 2013 11:33 am |
The rubber boots on the caliper sliders just pop out.
Posted: Tue Apr 30, 2013 1:10 pm |
Edward wrote: |
The rubber boots on the caliper sliders just pop out. |
Many thanks, another job for weekend.
