Posted: Fri May 10, 2013 5:11 am |
i recently bought the car and both the brake light and a headlight were not working so i got a few bulbs and set about changing them.
as i was changing the rear bulb it didn't look blown but i changed it any way (i also checked for loose wires,corrosion etc and everything looked o.k)
The headlight now works fine but the brake light still is not working. i have checked the 10a fuse (no. 20) and that is fine.
is there something simple i am missing here before i shell out for a new rear cluster?
any help would be greatly appreciated.
Posted: Fri May 10, 2013 5:40 am |
I would have said the fuse. Have you swapped the fuse with one that is known to work.
Are you getting 12v at the bulb connector?
Posted: Fri May 10, 2013 6:32 am |
macca1411 wrote: |
Are you getting 12v at the bulb connector? |
Thanks for the quick response.
i have just changed the fuse twice (both times with new ones) and still no luck.
i have ran a multimeter over the connector and everything seems fine.
Posted: Fri May 10, 2013 8:56 am |
You did fit the correct type twin filament bulb in the stop & tail lamp?
Posted: Fri May 10, 2013 9:53 am |
Corroded connection or damaged bulb holder maybe....rear clusters are cheap enough anyway, but if you know someone with a 206 try there's first.
Posted: Fri May 10, 2013 3:09 pm |
E5GDM wrote: |
Corroded connection or damaged bulb holder maybe....rear clusters are cheap enough anyway, but if you know someone with a 206 try there's first. |
thanks for the idea i got a mate to pinch his girlfriends car and i tried their cluster and it works fine. nipped down the local breakers and grabbed used one for a few quid. i now have all three brake lights working.
Thanks Again
Posted: Fri May 10, 2013 3:29 pm |
scott.jazz wrote: |
E5GDM wrote: |
Thanks Again |
Your welcome, glad it's sorted
