Latest: Mr-Koekwaus
Overall: 17125
Online Now [291]:
Visitors: 290
Today: 31843
Total: 99726091
Forums › The Car › 206 Problems › suspension creaks?
suspension creaks?
markj
PostPosted: Fri May 10, 2013 8:06 am Up
hi,
Right basically when the car is hot (if driving ffor a long time) the suspension creaks like hell only does it when car is hot any ideas what this maybe and possibly the overall cost?
thanks.
supreme clean north easts number 1 cleaning company!
PostPosted: Fri May 10, 2013 8:36 am Up
It might be the exhaust gasket ring where the two spring-clip is on the front-pipe to cat joint.
markj
PostPosted: Mon May 13, 2013 11:36 am Up
would this make the same noise if the belts needed a change?
PostPosted: Mon May 13, 2013 12:03 pm Up
No I wouldn't think so.
I just thought to mention it just incase, because you said it only does it when car is hot.
It's usually when the engine moves around too with that ring.
markj
PostPosted: Mon May 13, 2013 2:27 pm Up
hmm al have a check but mainly sounds coming from front suspension very creaky but thanks il check.
PostPosted: Mon May 13, 2013 2:45 pm Up
Get a knowledgeable mate to check the wishbones, bottom swivel joints and drop links. It isn't unusual for these to start to fail but need to be worked before they creak. So the creaking isn't directly caused by the car being hot just that you have driven it and the frequent suspension movement while driving has restarted the noise.
magistar
PostPosted: Wed May 15, 2013 1:12 am Up
Could possibly be worn/leaking shocks. I had a similar problem last year and turned out that I needed new shocks and drop links. Have a look around your suspension and see if there's any oil around the shocks (if your shocks is oil types)
markj
PostPosted: Fri May 17, 2013 5:25 am Up
thank you al get someone to check those hopefully have it sorted soon its mainly annoying haha
markj
PostPosted: Mon Jun 03, 2013 9:21 am Up
still have no luck with the creaking, today i turned the steering wheel and started creaking like mad could this be to do with steering rack ? and i think my pas pump is on its way as it makes some whineing noise when turning any help on how to change this a how to diagramme would be great thank you.
