Online Now [352]:
Visitors: 352
Today: 118580
Total: 154676604
Forums › The Car › 206 Problems › Argh French cars ;( speedo issues
00budham00
PostPosted: Tue May 14, 2013 1:23 pm Up
Start to drive speedo rises as should then drops off then as I accelerate it goes up to ten and then drop ffs , Iv had this problem before I took off rear abs sensors but they are linked right ?
All other dials work as should Wink
Car is a gti x reg 2000 plate
Thanks in advance
DREWDEN
PostPosted: Wed May 15, 2013 5:32 am Up
Cracked ABS ring by any chance.
206 2ltr Hdi glx 53 plate
PostPosted: Wed May 15, 2013 9:02 am Up
ABS has nothing to do with the speedo on a non plexed 206.
00budham00
PostPosted: Wed May 15, 2013 9:28 am Up
Oh :;(
PostPosted: Wed May 15, 2013 9:33 am Up
Have the drivers door on the safety catch & drive the car up to about 10mph.
If the interior light flashes while moving then the speed signal to the BSI is ok.
I would reckon this fault will be the speedo drive inside the instrument cluster.
PostPosted: Wed May 15, 2013 11:54 am Up
When slowing down does the engine revs dip a bit low? That's a sign that the ECU isn't getting a speed signal.
