Online Now [392]:
Visitors: 390
Members: 1
Today: 65145
Total: 156172364
Forums › The Car › 206 Problems › 206 1.6 GLX 1999 won't start from warm
NurseyKay
PostPosted: Mon May 20, 2013 7:03 am Up
i1334.photobucket.com/...9ff9a9.jpg
PostPosted: Mon May 20, 2013 7:04 am Up
MAP sensor without integral intake temp probe.
NurseyKay
Ok hope that has worked....
The sensor with the screw was replaced, I wiggle it's grey connector at the bottom of it down and then back up to make the car start
NurseyKay
PostPosted: Mon May 20, 2013 7:07 am Up
I was told it was called the air inlet sensor, hence I have been referring to it as that. Does the image help?
PostPosted: Mon May 20, 2013 7:08 am Up
Could be the connector itself, dirty contacts in the connector (not visible in the grey plug) or not related. Obviously it needs to click-lock into place to be fully-in.
DREWDEN
PostPosted: Mon May 20, 2013 7:10 am Up
Hi, Yours is a diesel yeah, would it make a difference that mine is petrol?
Sorry i missed this reply, my quote was from another site, which was very simular to your problem, and was a petrol car.
206 2ltr Hdi glx 53 plate
NurseyKay
PostPosted: Mon May 20, 2013 7:12 am Up
thats one thing it doesn't do - click to lock in position - it never seems really sited
PostPosted: Mon May 20, 2013 7:17 am Up
OK, with the help of a flat-head screwdriver, gently prise-up the tab (at the top) and take connector completely out. Re-insert and it should click once fully-in. Repeat the process 3 or 4 times just to give the contacts a scrub. It would be worth using some contact spray if you find this has affected behaviour of the symptom (hot/cold etc).
NurseyKay
PostPosted: Mon May 20, 2013 7:34 am Up
Ok did this.... I think it got a bit better siting, though it doesn't click cleanly into place, however in doing it, the top of the connection holder snapped off as I moved it, fortunately it doesn't seem to be affecting it's hold at all.
Do you recommend getting this replaced, and if so can I do it myself? Does it need doing?
PostPosted: Mon May 20, 2013 7:37 am Up
Is the bit that snapped the tab on the grey plug?
NurseyKay
PostPosted: Mon May 20, 2013 7:38 am Up
yes
NurseyKay
PostPosted: Mon May 20, 2013 7:39 am Up
the bit that snapped was the oblong piece across the top, over the two raised bits on my picture
PostPosted: Mon May 20, 2013 7:44 am Up
Well it would be worth splicing a new (2nd hand) connector on there anyway incase it has internal bent contacts and that was going to be my next guess, if you want to make sure about that connection being the issue.
It should not affect electrical contact in the mean-time, it would need to be done by a garage but it's a very small job.
See if you get any improvement now with what you did, otherwise might be the gray connector faulty all along or even a completely different issue as I said above.
DREWDEN
PostPosted: Mon May 20, 2013 7:45 am Up
Take the car back to the garage, that replaced your sensor (and use a bit of your charm) and see if he can test the power to the connector, so you can rule that out, if ok, ask him what else it could be.
You never know he might test and rule out other sensors.
NurseyKay
PostPosted: Mon May 20, 2013 7:46 am Up
Thank you, I will see how it behaves tonight when I try and start the car between patients.
Page 3 of 7
