Latest: heikkisj
Overall: 17126
Online Now [46]:
Visitors: 45
Today: 12312
Total: 100385049
Forums › The Car › 206 Problems › Problems with abs on 206 hdi 90hp
pistero01
PostPosted: Mon May 20, 2013 8:03 am Up
My car is a 206 2.0 hdi 90hp
The problem I have is this.
After sending to the new back brakes, an error appeared in the abs, which so far have not been able to solve.
My car comes with drum brakes with abs. I took aa tell me where is the problem and was told it is in the rear brakes.
Clean the sensors and the problem continues.
I said it may be the ABS reluctor RING - MAGNETIC, but priate not disassemble the drum which is the reluctor ring ...
Anyone have any photo as seen a brake drum of a 206 with abs inside?
Excuse my English, I do not speak the language very well.
I hope you understand ..
PostPosted: Mon May 20, 2013 10:15 am Up
Well have you changed the rear drums too along with new brakes?if you did,you should make sure that the new drums are for ABS model,as some 206 don't have an ABS system,you can see the different as the ring is a built in one,inside the wheel bearing.
pistero01
PostPosted: Mon May 20, 2013 1:11 pm Up
I have not changed the drums, just the brakes.
My question is if the captor takes the info pointing to the ring or side.
No what I mean?
