Latest: heikkisj
Overall: 17126
Online Now [320]:
Visitors: 319
Today: 38714
Total: 100371669
Forums › The Car › 206 Problems › steam from radiator expansion bottle cap
mikesrob
PostPosted: Sun May 19, 2013 2:25 pm Up
Hi, as my daughter was parking her peugeot 206, 14 petrol to-day she noticed a lot of steam and water coming from the expansion bottle cap, when the car had cooled down,I re filled the bottle with water, I noticed that the rubber seal inside the cap was not seated evenly in the groove but half on one groove and the rest on a lower groove, the seal also looked stretched,would this seal in this condition cause the car to overheat like this and allow coolant to escape or is there another reason? thanks in advance for any replies,Mike.
Tolkienfan001
PostPosted: Sun May 19, 2013 2:29 pm Up
Trade Rating: +13
Hi
If the seal / cap is not fitted properly I would assume you could lose coolant this way. I believe you can get a replacement from peugeot.
Is the car showing any other signs of overheating?
2005 1.4 16v Sport
Check out my 206 here!
206gti_chris
PostPosted: Sun May 19, 2013 2:56 pm Up
happend to me once when i filled the coolant to much and didnt screw the cap on tight enough
mikesrob
PostPosted: Sun May 19, 2013 2:58 pm Up
Hi Tolkienfan, the only other sign is a hissing sound from the cap area, which is probably due to the seal not sealing properly, car runs ok except for the escaping fluid/steam
mikesrob
PostPosted: Sun May 19, 2013 3:00 pm Up
will purchase a new cap tomorrow to see if the problem dissapears.
Tolkienfan001
PostPosted: Sun May 19, 2013 3:19 pm Up
Trade Rating: +13
Sounds like a plan Smile
2005 1.4 16v Sport
PostPosted: Mon May 20, 2013 5:50 am Up
New expansion bottle cap is a wallet busting £3.79 including the VAT from any Peugeot / Citroen main dealer.
Tolkienfan001
PostPosted: Mon May 20, 2013 8:04 am Up
Trade Rating: +13
Now I remember how I knew this. You told someone else the same thing the other day Smile
2005 1.4 16v Sport
mikesrob
PostPosted: Mon May 20, 2013 2:50 pm Up
Hi guys, update on the expansion cap situation, I bought a new cap today ( £5.20 ), went for a 15 mile run to test, the temp gauge went up to between 70 and 90 during the run, no sign of any steam or coolant loss when I checked after stopping, but the top radiator rubber? pipe felt very hot when I touched it, is this normal??.
Tolkienfan001
PostPosted: Mon May 20, 2013 2:58 pm Up
Trade Rating: +13
I would like to met the person that answers this! I have never taken the car for a run (to running temp) and then start touching parts under the bonnet to see if they are hot. Shocked Wink
2005 1.4 16v Sport
PostPosted: Wed May 22, 2013 12:37 pm Up
Tolkienfan001 made me laugh and he really meansd "yes" it is normal.
