Online Now [248]:
Visitors: 246
Bots: 2
Today: 20731
Total: 155739462
Forums › The Car › 206 Problems › aerial not working
aerial not working
dannyhimo
PostPosted: Tue May 21, 2013 9:16 am Up
bought my friends 206 off her about a month ago and have been doing little bits to fix her up, now i'm on to fixing the aerial, however I have no idea whats up with it. the radio doesn't pick anything up, ive swapped the head unit so i can confirm thats not the problem, as for the aerial itself on the roof this appears fine so i was wondering if anyone else had this problem and if they could point me in the right direction? thanks
PostPosted: Tue May 21, 2013 9:26 am Up
Have you checked the connection at roof level?
PostPosted: Tue May 21, 2013 3:16 pm Up
do you have the Aerial on the front or rear?
mattvaretto
PostPosted: Tue May 21, 2013 3:31 pm Up
Does the rear mount aerial fit if you swap for a front mount?
Razor34
PostPosted: Wed May 22, 2013 8:08 am Up
I have a front mounted aerial with this problem and I am currently waiting for a replacement round circuitboard which is located under the aerial base connected to the aerial cable from a scrappy as this part is not made anymore by Peugeot!!!
Will let you know if it works Smile
Ray
dannyhimo
PostPosted: Thu May 23, 2013 8:32 am Up
its a front mounted aerial and its all connected up and appears fine. Cheers Razor34, i know the bit youre talking about, i guess it could have got wet with being just below the aerial for 11 years! will be great to hear if it works!
Razor34
PostPosted: Tue May 28, 2013 7:37 am Up
Hi Dannyhimo,
Replaced that part and it does not make a difference. My last avenue now as everything else is pretty much changed is to change the whole aerial cable itself unless anyone else knows any difference - bloody Pugs!!!!
Ray
dannyhimo
PostPosted: Tue May 28, 2013 8:13 am Up
ah cheers for letting me know! i know bloody things, think I'm gonna trade in for a 90s Merc C230 in the not too distant future!
