Latest: ArtistKS
Overall: 17145
Online Now [100]:
Visitors: 99
Today: 16449
Total: 116073351
Forums › The Car › 206 Problems › Engine management light on
Delo
PostPosted: Tue May 21, 2013 10:46 am Up
PLanet 2000. Error codes
1st fault was permanent, brake light switch open circuit.
2nd fault was throttle discrepency, 40% sensor 1 & 52% sensor 2.
What parts do I need to replace on car?
206 hdi 2.0 2002
206
PostPosted: Tue May 21, 2013 3:28 pm Up
First:You need a new brake light switch,it's the one fitted on the brake pedal,easy to replace.
Second:It will be more helpful if you got the fault code,so we know exactly what to look for.
Delo
PostPosted: Tue May 21, 2013 4:13 pm Up
As requested codes
Po571
P0221
My brake pedal does not have a sensor fitted that I can see?
Hdi diesel
206
Tolkienfan001
PostPosted: Tue May 21, 2013 4:16 pm Up
Trade Rating: +13
Delo wrote:
As requested codes
Po571
P0221
Hdi diesel
It's on the passenger side under the glove box
2005 1.4 16v Sport
Check out my 206 here!
Delo
PostPosted: Tue May 21, 2013 4:28 pm Up
Cheers
What could other code be?
And once parts replaced will light go out or need turning off?
206
PostPosted: Wed May 22, 2013 4:40 am Up
P0221 - Throttle/Petal Position Sensor/Switch 'B' Circuit Range/Performance Problem
Possible causes
- Throttle Position Sensor (TPS) harness is open or shorted
- Throttle Position Sensor (TPS) circuit poor electrical connection
- Faulty Throttle Position Sensor (TPS)
- Fault Electric Throttle Control Actuator (or Throttle Body Motor)
- Accelerator Pedal Position Sensor (APP)
Electric Throttle Control Actuator consists of throttle control motor, throttle position sensor (TPS), etc. The throttle position sensor responds to the throttle valve movement.
The throttle position sensor has the two sensors. These sensors are a kind of potentiometers which transform the throttle valve position into output voltage, and emit the voltage signal to the Engine Control Module (ECM) In addition, these sensors detect the opening and closing speed of the throttle valve and feed the voltage signals to the ECM. The ECM judges the current opening angle of the throttle valve from these signals and the ECM controls the throttle control motor to make the throttle valve opening angle properly in response to driving condition.
Taken from www.engine-codes.com/P0221.html
The light should go out when it's repaired, but the code will still be stored until it's deleted.
Yours left hand drive by any chance?
Delo
PostPosted: Fri May 24, 2013 12:32 pm Up
Many thanks no right hand drive
206
DREWDEN
PostPosted: Fri May 24, 2013 1:36 pm Up
Hi Delo.
Tried to help you on your other thread.(ANTI POLLUSION FAULT)
It goes like this when you have an an anti pollusion fault come up on your MFD, your EML light comes on as well,
as in the senario with me, the mechanic told me to give it a good blast in low gears, to clear all the crap out of my cat. This cleared my fault. The mechanic then cleared the fault code (throttle position sensor) which i presume shows up when you have a anti pollusion fault.
Hope this helps.
206 2ltr Hdi glx 53 plate
Delo
PostPosted: Sun Jun 02, 2013 3:00 pm Up
FIXED.
Replaced brake sensor and replaced throttle sensor H20cooler reset my fault codes and no anti pollution fault anymore. Emlight no longer on.
Brake sensor was noticeably burnt out inside, throttle sensor requires special tool to access internallly so £20 one from breakers seems to work
206
PostPosted: Tue Jun 18, 2013 2:45 pm Up
macca1411 wrote:
P0221
Yes my car is Left Hand Drive :),that is why the location is diff. than the one you have Smile
and about the problem,glad it got fixed,and All the replies were helpful Smile
