Online Now [386]:
Visitors: 385
Today: 161249
Total: 155454228
Forums › The Car › 206 Problems › horrendous engine noise
copey
PostPosted: Wed May 22, 2013 2:46 pm Up
don't know if you guys can help bit of a long shot, but on my way to work this morning my engine started making some horrendously loud vibrating noize, rattling like hell sound as though the engine was a bout to fly out of the bonnet.
i stopped turned it off and had a look nothing seemed a miss at all apart from a slight bit of oil around one of the injectors, i turned the engine back on and it was still doing it, revved it a couple of times and it went away, drove it to work fine, drove it home nothing else happened
the car still drives fine, doesn't skip a beat or anything, but im assuming there must be some form of problem for it todo this in the first place
02 2.0 hdi d turbo
PostPosted: Wed May 22, 2013 2:54 pm Up
I believe some of your spark plugs stopped which made the engine vibrate,because it's working on 3 Cylinders instead of 4,so wait and see till it happen again,sometimes the coil pack can act up.
DREWDEN
PostPosted: Wed May 22, 2013 3:08 pm Up
Simular thing happened on mine last week, pour a bit of water around the injectors, (engine running of course) if one is leaking you will see bubbles foaming around the injector.
New washer on injector, then was ok.
206 2ltr Hdi glx 53 plate
Pricey3373
PostPosted: Wed May 22, 2013 3:26 pm Up
I had the same problem on my 1.4 hdi two weeks ago, it turned out to be the crank pulley which cost me £63 from europarts .
DREWDEN
PostPosted: Wed May 22, 2013 3:36 pm Up
Sorry to embarras you but its diesel
well you didn't,I guess I didn't pay attention to your sign. Smile
copey
PostPosted: Wed May 22, 2013 4:49 pm Up
was about to say the same, don't suppose there's much i can do whilst it isn't doing it.....hard to tell somebody to fix something when it aint acting up
02 2.0 hdi d turbo
DREWDEN
PostPosted: Wed May 22, 2013 5:09 pm Up
Test it now if i were you, I only noticed mine when i took the engine cover off to do something else. started the engine which was cold, and a right racket was coming from one of the injectors, went quiet after 1 min, i presume pressure had built up. If i hovered my hand over the injector i could feel a gust of air.
Like i said water test will show bubbles.
PostPosted: Wed May 22, 2013 5:30 pm Up
How do you know?
DREWDEN
PostPosted: Wed May 22, 2013 5:43 pm Up
Says at the bottom of his post like yours and mine does.
PostPosted: Wed May 22, 2013 5:44 pm Up
V9977 wrote:
How do you know?
The signature? Although it is better when the vehicle details are included in the post.
PostPosted: Wed May 22, 2013 6:45 pm Up
macca1411 wrote:
V9977 wrote:
How do you know?
Yep.
I stopped reading signatures ages ago. Don't know why.
Come to think of it, time to update yours macca, no?
copey
PostPosted: Thu May 23, 2013 2:26 am Up
macca1411 wrote:
V9977 wrote:
How do you know?
very true, my fault
to clarifiy its a 02 plate 2.0 hdi
02 2.0 hdi d turbo
waynemex
PostPosted: Thu May 23, 2013 2:40 am Up
I had the same with mine last month, its like all the rubber bushing within the wheel had worn away leaving the pulley with metal on metal between the inner and outer of itself. Get hold of the bottom pulley, you should feel any play in it.
eddie206
PostPosted: Thu May 23, 2013 8:44 am Up
Does it sound like your driving on a gravel track then someones stuck a plastic washing up bowl under the front of the car and it grinds as you drive along???
DREWDEN
PostPosted: Thu May 23, 2013 9:20 am Up
I would describe a rattleing noise like if you walked along a length of metal railings with a bit of metal bar.
Very hard to describe noises sometimes, everyone can interprit noises differently, thats why when people post
people can interprit differently.
