Online Now [380]:
Visitors: 379
Today: 56844
Total: 157246591
Forums › The Car › 206 Problems › 206 1.6 GLX 1999 won't start from warm
Go to page Previous  1, 2, 3, 4, 5, 6, 7
NurseyKay
PostPosted: Wed May 22, 2013 3:30 pm Up
eddie206 wrote:
I will tell you what id try...next time you fill up add some engine cleaner/fuel system cleaner/power boost fuel additive...
If you goto your local car parts shop and explain you want the best fuel additive to give the engine and fuel system a good clean they should point you in the right direction...
Just follow the instructions on the bottle and it will take a full tank of fuel but its worth a try and the additive should be under a tenner easily
REDEX is a popular brand of additive.
NOX is also popular.
WYNNS aswell....
All brands sell different variations so you could be spoilt for choice so ask the staff.
Thanks, will do this tomorrow
PostPosted: Wed May 22, 2013 3:54 pm Up
Asda has had Redex on offer recently. Think it was £4 per bottle.
NurseyKay
PostPosted: Wed May 22, 2013 4:37 pm Up
Great, thanks
DREWDEN
PostPosted: Fri May 24, 2013 9:41 am Up
Any updates Kay.
206 2ltr Hdi glx 53 plate
NurseyKay
PostPosted: Fri May 24, 2013 9:50 am Up
Hi yes, just back from another garage. (I appreciated the advice to go back to the other, but they didn't want my business!) I am now £220 worse off but have a new starter motor to show for it. I also have two holes in an air pipe diagnosed with instructions to get one from a scrap yard, as thats what is causing the revving by itself, which is back with a vengence, however....
It now starts when warm!!!!!
Thank you all for your advice.
DREWDEN
PostPosted: Fri May 24, 2013 10:14 am Up
Great news, don't want to dampen your spirits but £220 does seem a bit pricey for a starter motor and fitting, unless on that engine its realy, realy, akward to fit and time consuming.
PostPosted: Fri May 24, 2013 11:37 am Up
That's good news, pipe shouldn't be pricey to fix too I shouldn't think.
PostPosted: Tue May 28, 2013 3:11 pm Up
glad you got it fixed Kay,too bad that I'm not closer,I would of fitted the new starter motor myself Sad
Page 7 of 7
