Latest: Mr-Koekwaus
Overall: 17125
Online Now [397]:
Visitors: 396
Today: 62488
Total: 99567697
Forums › The Car › 206 Problems › What's the best way to get at the starter motor?
crocdino
PostPosted: Tue May 28, 2013 7:54 am Up
Will need replacing at some point as it randomly sticks.
Am I best getting at it from above or below?
If take the battery and battery tray out will it give me enough room?
GTI 138 facelift - Runabout
335d M Sport - Cruiser
PostPosted: Tue May 28, 2013 10:03 am Up
From below. It's only 3 bolts.
crocdino
PostPosted: Sun Jun 02, 2013 2:56 am Up
Without wanting to come across like a proper retard...
I'm struggling to even see it (I've not looked under, yet!) but I'd of thought I'd be able to see it from above?
Anyone got a pic from above or below with it highlighted?
DREWDEN
PostPosted: Sun Jun 02, 2013 5:09 am Up
Follow the + wire from the battery, will take you to it.
206 2ltr Hdi glx 53 plate
PostPosted: Sun Jun 02, 2013 5:43 am Up
Could be easier to access if the manifold was removed but that's extra time to do that.
crocdino
PostPosted: Sun Jun 02, 2013 6:50 am Up
That's it.. I saw that and thought it was it. Although it doesn't look like there's enough room to drop it out from below.
I'll get it in the air and have a look. It's not desperate as at the minute it's working fine.
Thanks for your help.
