Posted: Fri May 31, 2013 3:35 am |
Hi
When I turn on the car (normally in the morning) sometimes I hear a noise typically for a few seconds and it seems to be coming from somewhere near the glove compartment. The noise is very similar like someone is spraying a spray.
Any ideas what the problem might be?
Thank you in advance.
Posted: Fri May 31, 2013 3:50 am |
Possibly the brake servo. It's situated on the bulkhead just behind the glovebox. You could have an air leak which is causing a hissing sound.
Posted: Fri May 31, 2013 3:51 am |
air hissing from around the glove box could be the brake servo leaking.
with the car running but the radio and blower turned off , press the brake pedal and see if it makes the noise.
EDIT , maccas fast
Posted: Fri May 31, 2013 4:05 am |
Assuming it's a right hand drive car.
cartoonhead wrote: |
EDIT , maccas fast |
Has Mrs Macca been talking again
Hi
Thank you very much both for your replies. So is this something that needs to be solved as soon as possible or can I wait till the next service which is due in a couple of months?
Also if it is the a leak in the break servo is it something expensive to solve?
Posted: Fri May 31, 2013 4:17 am |
Its not expensive at all! I have a spare one lying around! Pm me if your interested. I would say its important as its your brakes..
Posted: Fri May 31, 2013 7:38 am |
Thank you very much for all your help and guidance, I will check with the mechanic tonight.
Posted: Sat Jun 01, 2013 10:59 am |
Hi belti, just curious to know what the mechanic has said.
I have a simular noise, to what your saying, an intermitent noise, like a loudish wheezing, something pumping up, lasts approx 10 secs, on starting the car up in the morning, not always mind you. It is nothing associated to the fuel priming i might add.
Never delved into it though, just presumed its something like the airbag doing a system check or some other self check on another part.
| 206 2ltr Hdi glx 53 plate | |
