Posted: Fri May 31, 2013 5:00 am |
Uz wrote: |
Zack wrote: |
Uz wrote: |
Zack wrote: |
Uz wrote: |
V9977 wrote: |
Driveshafts? |
How are driveshafts going to cause wheel wobble..? :S
Zack, check your discs..? might be warped. |
Ill have a look tomorrow jack car up put it in gear take wheel off tho yea?
Cheers |
Just jack it up, no need to put it in gear, take wheel off, turn the wheel do the calipers pointing inward and spin the disc so you can see the edge and check if there's and side to side movement. |
Ok thanks could it be control arms if not that?
cheers |
Na wouldn't cause wheel wobble. Have you checked the bolts are all done up correct lengths etc. I've had problems in the past with after market wheels and spacers where bolts have been a tad to long, you think you've tightened them up but it's that tiny bit thats causing you to have wheel wobble. |
Ok well ill have everything off tomorrow wheel and spacers check then discs and clean everything thank you
Posted: Fri May 31, 2013 5:11 am |
im having the exact same problem. Getting my tracking done later so i will let you know for sure
Posted: Fri May 31, 2013 5:13 am |
RedHDI wrote: |
im having the exact same problem. Getting my tracking done later so i will let you know for sure |
you going for just the fronts tracking or all over?
Cheers
Posted: Fri May 31, 2013 5:17 am |
Just the front. My cars drum brakes at the rear so I dont need them done do I?
Posted: Fri May 31, 2013 5:44 am |
Just to clarify, is this an actual visible wobble on the wheel or just something you can feel through the steering wheel, like a vibration?
Posted: Fri May 31, 2013 5:49 am |
macca1411 wrote: |
Just to clarify, is this an actual visible wobble on the wheel or just something you can feel through the steering wheel, like a vibration? |
See the wheel wobble y?
cheers
Posted: Fri May 31, 2013 6:00 am |
If you can see it, then something is either loose or bent. Narrows the possible causes down.
Posted: Fri May 31, 2013 6:05 am |
When I say wheel i mean steering wheel.
Posted: Fri May 31, 2013 6:07 am |
Uz wrote: |
V9977 wrote: |
Driveshafts? |
Like this:
Zack wrote: |
Wheels balanced 2x now all over
two new anti roll bar links done
Tracking is out could it be this?
Only shakes now and again when i go faster you can sort of feel it but there no wobble its like a dun dun dun hard to explain.
Cheers |
Zack wrote: |
When I say wheel i mean steering wheel. |
Posted: Fri May 31, 2013 8:30 am |
The drive shafts could be the cause as when people replace the boot they use a huge hose clip which sends it off balance due to the big lump on one side. If it does have hose clips put a proper drive shaft boot tie on or stainless cable tie, a regular cable tie should do it if you haven't got any metal ones.
Posted: Fri May 31, 2013 1:38 pm |
Getting tracking done tomorrow zack as the car was too low to go on the ramp
Posted: Fri May 31, 2013 1:39 pm |
Ok keep me updated please
Posted: Thu Jun 06, 2013 7:45 am |
RedHDI wrote: |
Getting tracking done tomorrow zack as the car was too low to go on the ramp |
How did you get on?
Cheers
Posted: Mon Jun 10, 2013 11:13 am |
Had this problem, after suspecting out-of-balance wheels / warped brake disk / wheel bearing, this forum helped to identify the cause: it was a buckled/warped wheel hub (the symptom was: strong steering wheel vibration when braking at high speeds).
You could see the wheel wobble:
www.youtube.com/watch?v=8yiQ0U50WdU
And the brake disk wobbles too (see gap between brake pads and disk):
www.youtube.com/watch?v=78sQBUto1JM
Problem gone once new wheel hub fitted:
www.youtube.com/watch?v=5S-xvrkgifE
Hope this helps in your tests
Posted: Mon Jun 10, 2013 12:32 pm |
Thanks for this should I change discs aswell then?
Cheers
