Latest: heikkisj
Overall: 17126
Online Now [46]:
Visitors: 45
Today: 14764
Total: 100324114
Forums › The Car › 206 Problems › Temperature Dial =- Flicks to hot
Quasar911
PostPosted: Mon Jun 03, 2013 10:19 am Up
When moving the temp dial to cold it quickly spins/flips to hot and wont stay in any variable position !!
Any Ideas,
not nice driving with heat blasting thru on nice weather like this.... Rolling Eyes
Deckchair5
PostPosted: Mon Jun 03, 2013 11:02 am Up
Sounds like the cable or mixer flap is jammed. Don't force it. Time to squeeze in and take a look at why the mixer valve at the other end of the cable isn't moving. You may be able to move the valve manually to at least shut off the heat and get some cool air going
Quasar911
PostPosted: Mon Jun 03, 2013 11:08 am Up
cheers - still have no radio so will get a torch and have a look behind the console.
bought a pre-plex radio and still didn't bloodywork or the RF ariel fit.
Deckchair5
PostPosted: Mon Jun 03, 2013 1:07 pm Up
Another thought if you are desparate to stop the heat until you get it fixed, if you put a clamp on one of the heater hoses close to where they go through the bulk head then you prevent heat getting to the heater and you will then have only cold air there in the cabin. Make sure the clamp is not going to damage the tubing surface though
Probably going to snow next week after our 3 days of Summer so you'll want your heater again in a hurry then Smile
Quasar911
PostPosted: Tue Jun 04, 2013 5:22 am Up
Probably going to snow next week after our 3 days of Summer so you'll want your heater again in a hurry then Smile.......
lol So true !!!
