Posted: Mon Jun 03, 2013 3:30 pm |
Hi guys, the electric sunroof on my 206 seems to have given up the ghost. It's stuck very slightly open and isn't responding to input from the switch.
I've read that the same fuse controls both the front windows and the sunroof, and as the windows are working fine I'm going to assume it's not that.
Any other suggestions for pinning down the problem? Any ideas are appreciated!
Posted: Mon Jun 03, 2013 3:40 pm |
you need the fixing kit for the sunroof,as I believe that you have a problem with the sliders.
Posted: Mon Jun 03, 2013 3:53 pm |
I have a spare sunroof motor if it is that. You can test that by getting a multimeter on the connection block and motor
Posted: Mon Jun 03, 2013 10:47 pm |
Wind the sunroof shut with the emergency close procedure then leave it alone.
Even when the 206 was a current production car Peugeot main dealers where pulling there hair struggling & failing to fix the crappy sunroofs.
Posted: Sat Jun 15, 2013 9:32 am |
How do I go about winding the sunroof shut? Could you explain the emergency close procedure to me? A quick Google isn't bringing anything up.
