Latest: DanDan17
Overall: 17128
Online Now [116]:
Visitors: 115
Today: 14925
Total: 100575624
Forums › The Car › 206 Talk › Opinions on Best Oil?
chief93
PostPosted: Tue Jun 04, 2013 10:50 am Up
As stated whats the best oil to use in my 1.6 16v xsi as i plan on dropping the oil out and changing the filters soon. Sometimes at present the car is making a slight ticking (tappety) noise on cold morning start ups then fine once warm so im hoping a decent oil replacement will solve this.
1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems."
Tolkienfan001
PostPosted: Tue Jun 04, 2013 11:01 am Up
Trade Rating: +13
Do you have a owners handbook? It says in there.
2005 1.4 16v Sport
Check out my 206 here!
iainlovatt
PostPosted: Tue Jun 04, 2013 11:04 am Up
total quartz! Smile
(My Garage)
chief93
PostPosted: Tue Jun 04, 2013 11:21 am Up
better than the likes of Castrol?
PostPosted: Tue Jun 04, 2013 11:56 am Up
Well it's what Peugeot recommend.
PostPosted: Tue Jun 04, 2013 12:36 pm Up
You need to use Total Quartz 5W/30 Synthetic
You will need 3,0 Liters with filter changed.
NICKST
PostPosted: Tue Jun 04, 2013 4:20 pm Up
Castral edge is very good I use that in mine. Seemed to run cooler on scan gauge as well.
kipper88
PostPosted: Thu Jun 06, 2013 1:28 pm Up
i have miilers nano oil in my 180 great stuff
206 gti 180 project in shutting tits up
bbunce1991
PostPosted: Fri Jun 07, 2013 4:37 am Up
I've got the 2.0 Hdi and use Mobil 1 turbo diesel ... Seems pretty good to me.
Brad
