Latest: Mr-Koekwaus
Overall: 17125
Online Now [139]:
Visitors: 138
Today: 50638
Total: 99668634
Forums › The Car › 206 Problems › key learning non preplex through PPS
heyziq
PostPosted: Thu Jun 06, 2013 9:07 pm Up
anyone know how to make it as my car had already had immobiliser lock on it
imageshack.us/photo/my....JPG/?sa=0
i want to unlock it
heyziq.com
PostPosted: Fri Jun 07, 2013 9:01 pm Up
So does the ECU say 'ECU status: Locked' all the time or some of the time?
Have you checked in the BSI for everything including stored codes and real-time parameters (locked/unlocked)?
Have you done any 'work' recently on it with Planet, and are you using clone interface?
Much more info needed.
PostPosted: Sat Jun 08, 2013 4:25 am Up
Could this fault pop up from clearing the codes too many times?
Thought I read somewhere that you could clear the codes about 50 times before the ECU locks out. Might be getting confused with something else though.
PostPosted: Sat Jun 08, 2013 5:26 am Up
No.
Locked-Unlocked status refers to wether the ECU has received a valid code from the BSI (immo chip accepted etc) to start the car.
After 50 service entries (history) you simply can't force-clear any trouble codes which means IF it goes into limp mode you're stuck.
PostPosted: Sat Jun 08, 2013 5:43 am Up
V9977 wrote:
No.
Ahh, thanks for that. I knew there was something about it going into limp mode.
