Online Now [1409]:
Visitors: 1409
Today: 25380
Total: 152070741
Forums › The Car › 206 Problems › Sony XPLOD radio not working
Simmo
PostPosted: Sat Jun 08, 2013 10:01 am Up
Unplugged my Sony radio yesterday which worked fine for a year and a bit to test if my mates radio would work, when i plugged mine back in the faceplate wont light back up.
Every now and again the unit seems to make a wizzing noise like its trying to eject but nothing more. I have tried repeatedly unplugging and plugging it back in and pressing the rest button on the radio but stilll nothing Sad
1.1 silver style www.206info.co.uk/Foru...52484.html
Simmo
PostPosted: Sat Jun 08, 2013 12:23 pm Up
any ideas?
PostPosted: Sat Jun 08, 2013 6:16 pm Up
Hi,
Was it ages since you removed the faceplate last time?
Apart from obvious spray on the gold contacts you should try bending them IF that turns out to help.
However, since you plugged another headunit in there maybe you blew a fuse. Check with a multimeter once you find the right one.
The whiring noise could be the other connection being still OK (permanent +ve) used for the radio memory and CD ejection with ignition OFF.
Simmo
PostPosted: Sat Jun 08, 2013 7:43 pm Up
Hi thanks for your reply and i think so, its probably been on their for almost a year. i checked the fuse on the back of both units and they both seem to be ok.
I will see what i can do with a multi meter. just seems strange how it was all only unplugged for a second then plugged back in again.
PostPosted: Sat Jun 08, 2013 8:58 pm Up
There should be another fuse actually in the cabin fuse compartment (near BSI) for stereo.
