Latest: heikkisj
Overall: 17126
Online Now [67]:
Visitors: 66
Today: 7073
Total: 100379832
Forums › The Car › 206 Problems › Powersteering hose
Powersteering hose
Berth
PostPosted: Tue Jun 11, 2013 12:51 pm Up
Hi
I went under my car yesterday to change the exhaust system, and discovered this bended hose, i think it's the high pressure hose ?
This is my first 206 Gti got it just 6 month ago, i belive that it had this bend from before, as the feeling hasn't changed.
But compared to my Mazda 3 it's "slower" or more resistent when turning the wheel.
Would this course the steering to be a little more "slow" ?
I can see in Servicebox that it's one part from the pump to the rack, will it be possible to change just the failed hose or do i need to get complete part?
Regards
Jesper
Denmark
PostPosted: Tue Jun 11, 2013 12:58 pm Up
206 power steering is heavy as standard.
The hose really needs replacing anyway as the kink will cause a weak point which over time could lead to the hose bursting.
PostPosted: Tue Jun 11, 2013 2:50 pm Up
That kink might have been caused by the fact it's not clipped in place. Can see the clips that are open. Or some work has been done kinking the pipe and whoever did it was a big enough cowboy to not refit the clips or replace them if they were broken.
Strange for a rubber hose to kink like that though.
Berth
PostPosted: Wed Jun 12, 2013 3:38 pm Up
The clips Where in place to begin with, i opened the clip as i had to remove the sub frame
Can the hose be changed or do i need a complete replacement from pump to rack?
/Jesper
206 GTi 2.0 2000 Trackday+ Daily
205 GTi 1.9 1987 Project
Citroen C4 Grand Picasso 2.0 VTR+ E6G 2008 Family car
Old cars
Mazda 3 1.6 16v Diesel 2008 - Peugeot 405 1.9 Diesel 1989 - Peugeot 309 1.4 Kick 1991 - Vw Polo 1.3 HIT 1986 - Mazda 626 1.8 1988 - Peugeot 205 GTI Project car - Ford Escort 1.6 16v 1996 - Peugeot 205 1.4 XR
