Latest: Andyblue64
Overall: 17123
Online Now [471]:
Visitors: 470
Today: 476
Total: 98511881
Forums › The Car › 206 Problems › air in diesel. pipes changed
Fifer
PostPosted: Wed Jun 12, 2013 12:46 am Up
Hi all
I am getting air in my diesel lines. Primer takes about 65 pumps to harden up. The plastic pipes under the airbox were replaced with rubber. The air inly gets in when the engine is running. If I pump the primer it will stay solid all night but when I drive it goes back to needing pumping and air is visible again.
Any ideas?
I have taped the push fits but no difference. Could a dodgy injector cause this?
1.4hdi 02
PostPosted: Wed Jun 12, 2013 3:01 am Up
Sounds like the airs being sucked in somewhere. Pump seals?
