Latest: dreyfalon
Overall: 17121
Online Now [514]:
Visitors: 513
Today: 56392
Total: 97582696
Forums › The Car › 206 Problems › How do I remove the Rear Subframe axle bushes?
clayt80
PostPosted: Wed Jun 12, 2013 5:31 pm Up
Having problems doing this as not sure how it goes together. Two of my mates are stumped too. Any help most welcome.
PostPosted: Thu Jun 13, 2013 3:23 am Up
The 4 rubber mounts? Cut them out.
DanT
PostPosted: Thu Jun 13, 2013 3:54 am Up
If you mean the ones that bolt the rear axle to the car, then fire is your friend. Sounds pikey but its a common, easy way of doing it.
Obviously with the axle off the car....
