Forums › The Car › 206 Problems › How do I remove the Rear Subframe axle bushes? |
Posted: Wed Jun 12, 2013 5:31 pm |
Having problems doing this as not sure how it goes together. Two of my mates are stumped too. Any help most welcome.
Posted: Thu Jun 13, 2013 3:23 am |
The 4 rubber mounts? Cut them out.
Posted: Thu Jun 13, 2013 3:54 am |
If you mean the ones that bolt the rear axle to the car, then fire is your friend. Sounds pikey but its a common, easy way of doing it.
Obviously with the axle off the car....
