Online Now [756]:
Visitors: 755
Today: 98830
Total: 157404532
Forums › The Car › 206 Problems › Oil Breather
Oil Breather
IceWhyte
PostPosted: Tue Jun 18, 2013 2:08 pm Up
Hey all,
Recently I have had a lot of problems with my 206 Quicksilver 16v. I have had the anti pollution fault for a while now and have changed the sensor which made it go away for a while but it returned.
Last week I was in the middle of a long journey and the car totally cut out and would start again after a few attempts but would continue to cut out at regular intervals.
The mechanic said it was the coil pack which I replaced but the problem persisted. I then noticed that the pipe that goes above the coil pack, pretty sure it is an oil breather pipe, had a hole in it and some oil came out. I taped it up and cleared the codes and nothing has returned, which is rare.
My question is, would that leaking pipe cause faults such as p0352 (which relate to the coil pack) and sensor faults to appear? The revs still hang a little bit but over all the car is running better.
Sorry for the long post and thanks in advance for any help.
PostPosted: Tue Jun 18, 2013 3:17 pm Up
I wouldn't think the leak would directly cause the code but could oil mist from the pipe cause the coil pack to short out?
The leaking pipe could (would) cause the revs to hold a little high as it will allow un-metered air into the inlet so you may still have an air leak on this pipe or you may also have the common problem of stepper motor (idle control valve) sticking. Is this car's idle controlled by an ICV? I am sure a knowledgeable member will be along to confirm soon.
IceWhyte
PostPosted: Wed Jun 19, 2013 2:06 pm Up
Sorry I don't know what an ICV is but thanks for the info, the revs only seem to hang when it is first started but since the air hole has been taped on the pipe, it has improved.
