Online Now [1307]:
Visitors: 1306
Today: 195362
Total: 151043176
Forums › The Car › 206 Problems › Funny noise when pushing clutch pedal
MrBombHead
PostPosted: Fri Jun 14, 2013 7:12 am Up
Hi,
This morning I made a trip to work and on the way I notices a bit of vibration coming from the clutch pedal when changing gears.
A mile or so down the road I started hearing almost like a scretching noise whenever I put my foot on the clutch.
Changing gear seems to be fine, no slipping and acceleration is fine when I put my foot down. It just seems to be the noise, but it is a worrying sounding noise.
Any ideas from experience at all?
I have a recording of the sound if that helps at all.
Car - 55 plate 206 180 GTi
Bombhead
My 206 - 206info.co.uk/Forums/v...23351.html
Facebook - www.facebook.com/Bombhead
PostPosted: Fri Jun 14, 2013 7:59 am Up
Release bearing?
MrBombHead
PostPosted: Fri Jun 14, 2013 8:46 am Up
macca1411 wrote:
Release bearing?
Not knowing anything about how a clutch works I did some research for your suggestion would certainly make sense. I think failure in any other part of the gear changing system would present much bigger problems than just a noise.
Will be taking the car down to a garage today.
Thanks for your response.
Bombhead
PostPosted: Fri Jun 14, 2013 4:31 pm Up
macca1411 wrote:
Release bearing?
What She Said
Lowiee
PostPosted: Sat Jun 15, 2013 8:41 am Up
dry release bearing
MrBombHead
PostPosted: Tue Jun 18, 2013 10:25 am Up
The guy at the garage is saying to replace the clutch is £380 + VAT and is 6.2 hours labour. (All approved parts)
Putting the total to £456.00
Does this sound like a rip off? or am I just in shock?
Bombhead
MrBombHead
PostPosted: Tue Jun 18, 2013 10:59 am Up
The £950.00 quote I just got from Peugeot gives me hope that the price I've been quoted isn't that bad.
Bombhead
While its apart in bits its just stupid not to replace the complete 3 part clutch kit.
You have to dismantle it to get at the release bearing anyway.
LUK / Sachs / Valeo for the clutch kit.
MrBombHead
PostPosted: Tue Jun 18, 2013 11:04 am Up
Not dismantled it to have a look, the guy says it's definitely the release bearing, and best to replace the whole lot. He did mention replacing something else, but I cannot for the life of me remember the name of it. He said its a "while your there" type replacement, and is included in the price he quoted.
Bombhead
Ben.M
PostPosted: Tue Jun 18, 2013 1:54 pm Up
Get the parts yourself (EuroCarParts, CarParts4Less etc.) and then the price should come down a bit, plus then you know exactly what you're getting fitted :).
Avoid the Transmech clutch kit if one is listed for your car, they are cheaper for a reason!
MrBombHead
PostPosted: Tue Jun 18, 2013 2:31 pm Up
Thanks for the info, will make sure I get the Valeo fitted rather than the Transmech
Bombhead
PostPosted: Tue Jun 18, 2013 2:36 pm Up
You want an LUK clutch kit not a Valeo Wink
broadblaster
PostPosted: Tue Jun 18, 2013 3:06 pm Up
as above go for the LUK kit as the valeo kit seems to be a weak point on the 180's on both of mine it was the thrust bearing trying to eat its way through the pressure plate.
i personly would change the input shaft bearing/seal while you have got it all apart as again both of my ones were very worn.
on a back road playing
