Online Now [492]:
Visitors: 491
Today: 110210
Total: 156988091
Forums › The Car › 206 Talk › will gti discs fit my 1.4
Forum Index › 206 Talk
kizza93
PostPosted: Wed Jun 19, 2013 12:24 pm Up
I have a 1.4 8v and i need new discs was looking at the gti discs will they be a straight fit and will i need to change calipers
PostPosted: Wed Jun 19, 2013 12:27 pm Up
You need the complete set of matching GTI callipers, pads & discs.
It all bolts straight on.
Lex206
PostPosted: Wed Jun 19, 2013 12:28 pm Up
the gti discs are too big,you need to get the calipers from a 1.6 16v or gti..or 180 for even bigger discs on your car
Megane 225 RS
PostPosted: Wed Jun 19, 2013 1:42 pm Up
Buy the calipers first. Find out what age and preferably build date (can be found on hoses under the bonnet, seat belts etc) of the GTi or XSi that they are from and then buy the correct new discs and pads. Don't do it the other way round.
Andrew
PostPosted: Wed Jun 19, 2013 1:54 pm Up
Go for the GTi180 calipers that will enable you to fit the matching 282mm brake discs. Good advice above buy it all from the same car.
But whatever you do, don't buy the 307 2 litre calipers that also hold 282mm discs, and buy GTi180 discs. They have different offsets
My 206 thread
www.detailedbyandrew.com
Lex206
PostPosted: Wed Jun 19, 2013 2:38 pm Up
what size wheels r u using?
if its 14 inch,gti calipers should fit(?)but 180 wont.
Megane 225 RS
RoweY
PostPosted: Wed Jun 19, 2013 3:31 pm Up
I was wondering this as well so thanks Very Happy
14hdi
PostPosted: Wed Jun 19, 2013 3:48 pm Up
Yeah had 266 under my 14" steel wheels. Close but not rubbing.
kizza93
PostPosted: Wed Jun 19, 2013 4:39 pm Up
Ok cheers i have 17s on there at the min so i think ill have enough room
14hdi
PostPosted: Wed Jun 19, 2013 5:46 pm Up
Get 207 gti brakes.
302mm disc.
Calipers bolt straight on and clear standard gti wheels.
