Online Now [446]:
Visitors: 444
Bots: 2
Today: 92319
Total: 157281643
Forums › The Car › 206 Problems › strange missfire
strange missfire
mikesrob
PostPosted: Thu Jun 20, 2013 2:53 pm Up
Hi, my daughters w reg 14 206 has an intermittent missfire, goes for days with no missfire,then all of a sudden it missfires, the missfire varies from a slight miss to an all out, hardly moving missfire, not weather related as it happens in all weathers, coil pack / plugs have been changed.No fault codes come up at all. The only thing i have noticed is that there is a crack around the exhaust back box and it is loose, could this cause a missfire?, thanks for any replies in advance , Mike
lukepug19
PostPosted: Fri Jun 21, 2013 3:47 am Up
a cracked exhaust cant cause a misfire you could have an intermittant injector fault or quite possibly be ecu related
234re
PostPosted: Fri Jun 21, 2013 10:47 am Up
Or driving related, due to condition of the valves.
PostPosted: Fri Jun 21, 2013 10:54 am Up
What make of coil & what make of spark plugs where fitted?
PostPosted: Fri Jun 21, 2013 10:56 am Up
And when, before or after the misfire appeared?
mikesrob
PostPosted: Fri Jun 21, 2013 11:04 am Up
dont know the make of coilpack,nkg plugs, misfire was there before putting in new coilpack and plugs
HowlingMadMurdock
PostPosted: Fri Jun 21, 2013 2:23 pm Up
Is the tickover normally stable? If it doesn't idle properly I'd follow Timon's throttle body/sensor cleaning guide, it does make a difference.
Have you tried any fuel treatment? My 1.4 was running like a bag of nails when I got it, followed Timon's guide, filled up with petrol and put some fuel treatment in, did a 320 mile run on the A1, and she felt a different car after that. Maybe the injectors just need a bit of clean?
I ain't nuts, I'm condiments, I've been promoted
