Posted: Sun Jun 16, 2013 12:52 pm |
Posted: Sun Jun 16, 2013 1:24 pm |
ive got a simular noise also, i notice mine mostly on the 'over-run' would be interesting to find out whats causing it
Posted: Mon Jun 17, 2013 1:03 pm |
bump
Posted: Sat Jun 22, 2013 3:38 pm |
no knowledge from anyone?
Posted: Sat Jun 22, 2013 10:43 pm |
When i first listened i couldnt pick it up(maybe others are same hence no response?)but after listenin 3/4times there is a whiney sound and to me if you give all the pulleys etc a good lube up with wd40 and the soynd is still thete it actualy sounds like a bearing to me...now that coyld be a number of things...
So if people watch this over a few times they may be better placed to comment but u could inquire about bearing/pulley/water pump whine as a possible cause?..
Posted: Sun Jun 23, 2013 7:41 am |
It's the cambelt I think. Well mine sounds similar to that! And I had a new timing belt kit put on and it whined like that.. And still does when it's hot but garage reckons its normal.. So who to beleive. Get it checked.
Posted: Sat Nov 02, 2013 7:20 pm |
Idler pulley needs replacing most probably
