Online Now [335]:
Visitors: 334
Today: 181528
Total: 155474176
Forums › The Car › 206 Talk › Coil pack mod 6555.K9 Condensor???
Forum Index › 206 Talk
Go to page Previous  1, 2
MadzeR86
PostPosted: Tue Jun 25, 2013 7:19 am Up
Here is the 6555.K9 Condensor installed. Just ran into a problem! The airbag warning light is now flashing, Tried disconnecting and reconnecting the battery but still the same. I must of disturbed something while under the hud Mad
PostPosted: Tue Jun 25, 2013 7:27 am Up
'Don't think there's much air-bag wise under the hood tbh.
Did you do any work in the cabin?
Any moving of seats back and forth etc?
MadzeR86
PostPosted: Tue Jun 25, 2013 9:51 am Up
No have haven't touched any seats or fuses inside. I looked under both drivers seat and passenger for wires or lose connections but cant see any wires. Also looked under the carpet next to both doors and all looks ok.
Will i reset the ECU/BSI ? Ive seen so many different directions on how to reset but which one works?
PostPosted: Tue Jun 25, 2013 2:06 pm Up
There is no BSI reset for non-mux as such.
pug206lx
PostPosted: Tue Jun 25, 2013 5:46 pm Up
If there's no wires under the seat the next thing is most likely going to be the spool behind the steering wheel which is actually quite straight forward to replace.
Best to check for sure on some diagnostics though.
MadzeR86
PostPosted: Tue Jul 02, 2013 7:07 am Up
Well the light has mysteriously disappeared Very Happy thank christ as its due an NCT.
GalwayGuy
PostPosted: Mon Jun 15, 2015 8:06 am Up
Hey, I'm in a similar spot with no sign of my condenser. As I'm fitting a new Valeo coil pack do I still need the condenser? And if I do is one from a scrap yard ok for the job?
Page 2 of 2
