Online Now [687]:
Visitors: 686
Today: 103948
Total: 156819042
Forums › The Car › 206 Talk › Air box pipes below
Air box pipes below
Forum Index › 206 Talk
Majid
PostPosted: Tue Jun 25, 2013 6:47 am Up
Hi
I wanted to replace all pipes below the air filter housing
How many pipes are there?
What are they called?
Is there a pump attached to draw air in?
Any help would be appreciated?
Peugeot 206, 1.6, 16 valve
2003
eddie206
PostPosted: Tue Jun 25, 2013 8:20 am Up
If you need to ask what there called ?and IS THERE AN AIR PUMP to draw air in?i would just leave anything under the bonnet alone man...Its your health and safety dude.
Majid
PostPosted: Tue Jun 25, 2013 8:52 am Up
My air filter keeps getting wet
So I need to replace them
2003
MadzeR86
PostPosted: Tue Jun 25, 2013 11:14 am Up
If you jack up the car and take off the front passenger wheel and remove the wheel arch plastic cover you can get a better view of the airbox ducting. Maybe a crack or something is letting in water?
PostPosted: Tue Jun 25, 2013 2:54 pm Up
well since you are having a 1.6 16v engine,then you have an NFU engine code,which don't have the pipes for the air filter behind the wheel arches
Majid
PostPosted: Tue Jun 25, 2013 5:26 pm Up
Hi
Thank you guys for helping me out
Where are the pipes located?
Cheers
2003
PostPosted: Tue Jun 25, 2013 5:47 pm Up
From your VIN this is what the air supply system should look like
