Latest: elelectricistadeMateo
Overall: 17127
Online Now [78]:
Visitors: 77
Today: 8185
Total: 100406400
Forums › The Car › 206 Problems › Coil pack connector
Coil pack connector
IceWhyte
PostPosted: Wed Jun 26, 2013 12:00 pm Up
I have had a several faults for a while now, mainly anti pollution but sometimes a cat converter fault too.
I have replaced the o2 sensor, the coil pack and all the breather hoses and the problems still persisted.
Today I found out the source of the problem, it is the connector for the coil pack. When I nudge the connector it starts to run rough and sometimes cuts out. This also spurs the cat converter fault.
My question is where the hell can I get a replacement cable for the coil pack?
Also, I have a coil pack and 02 sensor for sale. Haha.
PostPosted: Wed Jun 26, 2013 12:08 pm Up
Peugeot / Citroen main dealer.
PostPosted: Wed Jun 26, 2013 1:07 pm Up
You can get all plugs and terminals from the dealer. All plugs are on Servicebox too. You just need to be sure of which one you want. You need to visually find the required plugs.
It's in the Fastenings, fixings and connectors catalogue on the left hand side once you've selected the car model.
PostPosted: Wed Jun 26, 2013 1:39 pm Up
Trouble is prices on most of those PSA connectors as spare new are absolutely diabolical.
Scrapy or 2nd hand for me every time on those.
IceWhyte
PostPosted: Wed Jun 26, 2013 1:41 pm Up
Thanks for that info but it doesn't appear to be in the list on the Servicebox site. I will maybe just try people who are breaking a similar model.
PostPosted: Wed Jun 26, 2013 2:52 pm Up
Cant say I've ever found the prices to be too high and I've bought a few of them.
PostPosted: Wed Jun 26, 2013 3:19 pm Up
OK, maybe I was unlucky because a couple of nothing-special ones I looked-at quite a while back were something like 25GBP each. Shocked
Perhaps I wasn't looking at the right part.
IceWhyte
PostPosted: Thu Jun 27, 2013 4:58 am Up
Does anyone know if that connector for the coil pack has a connector on the other end or does it go into the wiring loom? I still can't find the correct cable, nightmare.
PostPosted: Thu Jun 27, 2013 6:03 am Up
Straight into the loom.
PostPosted: Thu Jun 27, 2013 6:07 am Up
Is this not it?
IceWhyte
PostPosted: Thu Jun 27, 2013 8:57 am Up
No I think that could possibly be the grey connector, mine is the black one. It connects to the side of the coil pack rather than the middle.
PostPosted: Fri Jun 28, 2013 2:42 am Up
4.28 EUR.
Pas mal..
