Latest: flipflap
Overall: 17140
Online Now [224]:
Visitors: 223
Today: 37737
Total: 113944826
Forums › The Car › 206 Problems › 206 Diesel hdi 1.6 broken ???
Essex1
PostPosted: Thu Jul 04, 2013 1:08 pm Up
Sad Would really appreciate some help. I bought a 2004 206 diesel last night. Drove fine all the way home.
Started fine this morning, drove round the corner slowly, engine completely died. No spluttering just stopped dead.
Car wouldn't start, there is a code in the dash display....a spanner symbol then 10250.
Feel like I've searched the whole internet and cannot find anything relating to this error.
Left the car all day, tried to start it again on the way home from work, nothing.
Any info gratefully received!!
PostPosted: Thu Jul 04, 2013 1:15 pm Up
That's telling you how far to next service.
Essex1
PostPosted: Thu Jul 04, 2013 1:20 pm Up
Thanks for your reply. Now I feel a right Essex Girl!!!!!
If you could just get it started that would be great Smile
Lecktorious
PostPosted: Thu Jul 04, 2013 1:36 pm Up
Trade Rating: +59
Take it to a garage that has proper diagnostic equipment and get the codes read.
1.6 HDi = expensive to repair.
'98 Nile Blue 306 GTi 6
Does the engine turn over on the key or is it completely dead?
Have you let it get low on fuel recently?
PostPosted: Thu Jul 04, 2013 1:40 pm Up
Most likely why the previous owner got rid of it in first place Wink
Essex1
Engine turning over. Fuel indicator shows just below half full.
I only picked it up last night so don't know if it's run dry recently.
PostPosted: Thu Jul 04, 2013 1:46 pm Up
Private or trade purchase?
If it's trade, then tell them to get it sorted or refund your money as it's not fit for purpose.
Private is slightly longer winded, but could get a partial refund on the price if they are decent people.
Essex1
PostPosted: Thu Jul 04, 2013 1:56 pm Up
Essex1
PostPosted: Thu Jul 04, 2013 1:59 pm Up
Was private purchase. Bought as seen so it's my problem now.
Thought it would be a good idea going from an ST to a diesel, but still wanted something with at least a bit of go in it. Now it's going nowhere!
Got it all booked in for cam belt and service next week to be on the safe side. Just need to get it to the freaking garage now!
pug206lx
PostPosted: Thu Jul 04, 2013 2:13 pm Up
Between the time that you picked it up to the time that it stopped did the fuel gauge move at all? Might be worth you putting a can of diesel in it to see if it will run, it wouldn't be the first time a fuel gauge was faulty if it does start.
By the way, just so you have the information, the 1.6 has no lift pump under the back seat. It runs off a mechanical pump in the engine bay that's driven by the timing belt, and there should be a rubber piece inline with the diesel filter somewhere that you can pump to bleed the fuel through. Might be worth giving this a few squeezes too.
Essex1
PostPosted: Thu Jul 04, 2013 3:04 pm Up
I have only driven it about 12 miles in all since collecting so can't really say if the fuel has gone down.
Will have to get someone out tomorrow to diagnose. At least I should have some idea what the problem is then.
DREWDEN
PostPosted: Thu Jul 04, 2013 4:01 pm Up
I would be well surprised if someone letting a car go leaves half a tank of diesel.
Maybe he or she didn't want to elaberate that the fuel gauge is nackered, not nice if thats the case.
206 2ltr Hdi glx 53 plate
eddie206
PostPosted: Fri Jul 05, 2013 4:12 am Up
The car might be dry with a faulty gauge..spend a fiver on a can of diesel and give it a go...dont firget to try to pump it a few times first where above said...will save you the cost of a loader to the garage...
PostPosted: Fri Jul 05, 2013 2:07 pm Up
Some of the ideas people are throwing out nowadays......... I would be checking fap pressures, boost lines for turbo failure (oil blocking them) and see if the ecu is unlocking
