Online Now [318]:
Visitors: 317
Today: 87398
Total: 157276773
Forums › The Car › 206 Talk › New 206 owner questions.
Forum Index › 206 Talk
buseng
PostPosted: Thu Jul 11, 2013 9:37 am Up
Firstly I am new on here so please bear with me.
I have just bought a September 2005 (55) 5 door 206 SE with a 1.4 8 valve petrol engine. As the handbook is pretty generic I am not sure what functions my car should actually have. It has digital climate control, auto wipers/headlights, factory alloy wheels, no alarm & a smaller 2 line mfd.
As a start I don't think my car has deadlocking, one key button press only locks the doors normally & a second press activates the "find my car" feature. Can deadlocking be enabled on this vehicle? (if it shouldn't already have it). Also there is no seatbelt warning, so again I assume it is not fitted.
Now the big question, I would like to fit the larger 3 line mfd, but it seems a bit of a minefield. I have seen several on Ebay but several part numbers are given. My current small unit is 96564642XT A00.
The ones I have seen have these various part numbers,
9641014877 B02,
9656464377 C00,
9650242977 C00,
9647409777,
9646005377
Can anyone confirm whether any or all of these will work on my car please? Obviously they are all PPT40 3 bulb versions, but I don't know what the different part numbers mean.
Sorry for the long rambling first post & thanks in anticipation.
PostPosted: Thu Jul 11, 2013 9:39 am Up
Those aren't Peugeot part numbers
PostPosted: Thu Jul 11, 2013 9:48 am Up
Seatbelt warning needs the wiring loom to be there, white 2 pin plug normally hidden under the carpet along with the side airbag wiring.
Seatbelt buckle with sensor needs fitting & BSI configuration.
Deadlocks need ALL the standard door lock motors to be changed for the deadlocking type, BSI configuration & possibly door wiring looms changing ( depending on what looms are already inside the doors )
Just get a 3 line PPT 40 display of a multiplexed 206.
What's the VIN number?
You can get the exact spec it left the factory with of Peugeot Service box.
buseng
PostPosted: Thu Jul 11, 2013 9:57 am Up
Thanks for the quick replies, The part numbers are on the units, maybe Sagem numbers.
The VIN is VF32AKFWF44787794.
Thanks again.
PostPosted: Thu Jul 11, 2013 10:05 am Up
Vehicle characteristics
Vehicle family 206
Build code 10476 83 1 0141
Warranty Start Date 13/09/2005
BER e2*98/14*0237*07
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 206
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL XS LIGHT
ENGINE INJECTION TU3JP
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EXL - PAINT OBSIDIAN BLACK
INTERIOR TRIM TYPE MERLIN CLOTH + "HH" EFKA
UPHOLSTERY COLOUR "FX"
GEARBOX (CHARACTERISTICS) BVM MA5 / N
ENGINE (TYPE) TU
OTHER BADGE WITHOUT FULLER BADGE
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE SE
TRIM LEVEL XS LIGHT
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 19X17
Fuel supply-Engine
FUEL FILLER CAP FUEL CAP WITHOUT LOCK
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
ENGINE (TYPE) TU
CATALYTIC CONVERTER 3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
OPTIMISATION OF VEHICLE’S CONSUMPTION WITHOUT FUEL CONSUMPTION OPTIMISATION
COOLING MOTOR RADIATOR TH : 18-16 DM2 PAS 1 ALUMINIUM MECHANICAL
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
RHEOSTAT RHEOSTAT
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITH ACCELEROMETER
DEVICE (ANTIPOLLUTION) WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 FAN - 2 SPEEDS 250W 70WAERO
FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING SAGEM
TANK FILTER RESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) MANUAL THROTTLE BODY (ENGINE AIR INTAKE)
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 16 X 65
WHEEL STYLE WHEEL TORNADE 14 POUCES
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
GEARBOX TYPE (TYPE APPROVAL) GEARBOX MA/5 N TYPE
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 68
TYRE (SIZE, TYPE) 175X65X14 T TYRES
WHEELS FITTED 5,5" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
GEARBOX TYPE MA
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR ANTI-ROLL BAR DIAM 19
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 20
SERVICE BRAKE ELECTRONIC BRAKEFORCE DISTRIBUTION
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT ABS TEVES MK70
STEERING (OPERATION) ASSISTED MANUAL STEERING
PEDAL BRACKET (TYPE) PEDAL STANDARD
Body fittings
HORNS HORN STANDARD
AERIAL SHORT ROOF AERIAL
FINISHER (SELF-ADHESIVE) WITHOUT DOOR PILLAR DECORATION
SIDE MOULDINGS (TYPE) BODY COLOUR LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE) APOLLO TYPE
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR MANUAL-FOLD BACK
EXHAUST TAILPIPE TRIM WITH EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING BULKHEAD SOUNDPROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK PLUG FRONT FACADE
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COLOUR FRONT/REAR SPORT BUMPER WITH RUSH
MUDFLAP REAR WHEEL FRONT MUDFLAP
LUGGAGE RACK MOUNTING WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) DRIVER’S DOOR MIRROR ELECTRIC CONTROL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
SPARE WHEEL EMERGENCY WHEEL
EXTERIOR ACCESSORIES BODY COLOURED EXT HANDLE+FLAP TRIM+EXT MIRROR
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) EXT MIRROR ASPHERICAL GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) ATHERMAL WINDSCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER FRONT CIGAR-LIGHTER
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
LUGGAGE COVER WITHOUT LUGGAGE COVER
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
AIR CONDITIONING HEATER MATRIX WITH REAR HEATING
SPEED GRADUATIONS GRADUATION MPH
GRAB HANDLES FR + RR HANDLES WITH HOOKS
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE LONG CONSOLE + REAR AIR DUCT
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
LOAD SPACE LIGHTING GLOVE-BOX LIGHTING
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT SHINY FASCIA + BLACK BUTTON
MISC. INT. LAMPS LESS INTERIOR LIGHT
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 210 KM/H OR 135 M/H ALUMINIUM LAND
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
PROTECTIVE COVER WITH PROTECTIVE BATTERY COVER
RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT ADJUSTMENT DRIVERS FIXED LATERAL BEARING
FRONT PASSENGER SEAT ADJUSTMENT PASSENG FIXED LATERAL BEARING
DRIVER’S SEAT FOLDING W/O FOLDING DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
STOWAGE BIN WITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT ELECT CONTR RR WINDOW LIFTER + LOCK SYSTEM
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (CLOCK AND OR TEMP)
CLOCK WITHOUT CLOCK
OIL GAUGE STD OIL LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ON-BOARD COMPUTER NO COMPUTER
EQUIPMENT PACK W/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE) NEUTRAL FINISH INSIDE DOOR HANDLE
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
FRONT SUN VISOR DRIV+PASS SIDE (W/O NOTICE)
STORAGE (DRIVING POSITION) GLOVE BOX + NEUTRAL SWITCHPLATE
RADIO RECEIVER "RD3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
RHEOSTAT RHEOSTAT
STORAGE (OTHERS) STORAGE COMPARTMENT FR + RR DOORS + WALLET
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE WITH BOOT TIDY
CARPET NEEDLED CARPET DILOUR F550
LIGHTING TIMER NOT ADJUSTABLE TIMER
SWITCH ELECTRONIC ANTI-THEFT KEY
TRIM ADAPTATION GEAR LEVER KNOB PLASTIC+CHROME INSERT
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE + AUTOMATIC CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 3 BRANCH
STORAGE SPACE LOCKS GLOVE-BOX WITHOUT LOCKING
Electrical
ALTERNATOR ALTERNATEUR CLASSE 8+
HORNS HORN STANDARD
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 2
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
MULTIPLEXING MULTIPLEXING ASSEMBLY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT WITHOUT FIRST AID BOX
RADIO HEADPHONE SOCKET WITHOUT ACCESSORIES SOCKET
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 HF PLIP KEY + 1 SINGLE MAIN KEY
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
buseng
PostPosted: Thu Jul 11, 2013 10:17 am Up
Thanks very much for that, very useful.
bruce
PostPosted: Thu Jul 11, 2013 4:28 pm Up
I bet your exhausted after all that typing mr bsi...haha
