Forums › The Car › 206 Problems › 206 torsion bar |
Posted: Tue Jul 16, 2013 6:14 pm |
Hi guys, basically the previous previous owner of my 206 lowered the car at the back and never changed the shocks, when I picked the car up and drove it home the torsion was banging on the bump stops and making a really loud bang, so I bought stiffer shockers, put them on then went back to how it was before I swapped them over a few days later which is basically a bumpy but soft ride which is making it bottom out.. How do i get sround this? higher it up? or any other solutions as i like the ride hight! Help please!
Posted: Wed Jul 17, 2013 6:16 am |
Its too low.
Posted: Wed Jul 17, 2013 6:54 am |
Pictures...
Posted: Wed Jul 17, 2013 9:01 am |
Raise the rear or cut the bump stops like what I did
| Team Impossible Possible
