Latest: Willy.Sea
Overall: 17168
Online Now [65]:
Visitors: 64
Today: 47076
Total: 128547714
Forums › The Car › Solved 206 Problems › Need your help: Temp gauge flying into red then back again!!
hamed206
PostPosted: Wed Jul 24, 2013 7:41 am Up
What is the real root cause of this issue????????
I have seen this problem being posted by some persons in some other forums with no proper solution or real identification of the root cause of this issue.
My car starting to do it frequently today. While driving, the temp gauge would jump to red and back again like crazy. The A/C disconnect and connect each time the gauge is flying to red.....kept doing it like crazy!
We are in the summer, it was very hot in the morning. The problem annoyed me so much. It kept happening and I was not able to operate the A/C properly.
This is not the first time it happens. It used to happen many times since I bought my car. My car is 8v 1.4, 2000.
Please advise about such a problem. Anyone faced this? I'm sure there are some. So I need your kind attention here.
M
Hamed
DREWDEN
PostPosted: Wed Jul 24, 2013 8:03 am Up
Have you sorted the previous post yet, starting problem.
If so was it battery or starter motor.
206 2ltr Hdi glx 53 plate
hamed206
PostPosted: Wed Jul 24, 2013 8:08 am Up
It was not the battery because we tested it and tried to replace it and the problem persisted.
Haven't tested the starter motor yet which is highly suspected. But will post the results ASAP.
Thanks.
Hamed
DREWDEN
PostPosted: Wed Jul 24, 2013 8:19 am Up
Not trying to complicate things, but just trying to get a better picture for people, who might be able to help you.
On the 1/07/2013 you seemed to have problems with your A/C then with no outcome, or did you sort it.
May be relevent to this post if you haven't.
hamed206
PostPosted: Wed Jul 24, 2013 9:18 am Up
No DREWDEN. This problem is not related to the A/C. Even when the A/C is off, the temp gauge would fly to red and back again. It happens in the morning, at night, and every time.
Hamed
DREWDEN
PostPosted: Wed Jul 24, 2013 11:07 am Up
uk.answers.yahoo.com/q...414AAPq0lC
This may help you.
Check the earth strap, the earth strap could also be starter motor prblem as well.
14hdi
PostPosted: Wed Jul 24, 2013 11:09 am Up
My sisters car once did this, turned out to be the temperature sensor.
Get it onto pp2000!!!
Johnbyron
PostPosted: Wed Jul 24, 2013 12:35 pm Up
As 14hdi said get it plugged in, sounds like an electrical problem to me, if the gauge shoots up to red line very fast and comes back down fairly sharpish too then I very much doubt your actual coolant temp is going up and down that quick so probably just the guage
hamed206
PostPosted: Wed Jul 24, 2013 7:28 pm Up
It is not just the gauge because the fan kicks at high speed with every temp warning.
Hamed
hamed206
PostPosted: Wed Jul 24, 2013 7:29 pm Up
I got it sorted today. I hope it won't turn back again!
It was the thermostat, not opening or closing properly, so the water was not getting cooled through the radiater (we found hot engine and cool radiater). Also it seems that the existence of air in the water cycle was causing a confusion with the temp reading and making the temp gauge flying into red and backing again.
It turned to be neither the coolant sensor (the brown plug) nor the earth cable.
Now the A/C is working normal because no high temp alarm.
Thank you all.
Hamed
DREWDEN
PostPosted: Thu Jul 25, 2013 5:02 am Up
Well done for posting a sucessful outcome.
Will help other people who come accross simular problem.
hamed206
PostPosted: Thu Jul 25, 2013 11:11 am Up
Yes. You are absolutely right DREWDEN. Sorry if I missed this in my previous posts Smile
Hamed
Marius206
PostPosted: Sun Aug 25, 2013 1:25 am Up
Hi. That sounds similar to the problem i have now encountered, except that the STOP sign AND High temp stays on and at max, with fan on. Water is not boiling,and cooling itself seems fine.
Could this be airlock as well?
